Author Topic: Low Miler 16valve  (Read 2335 times)
Offline The Hoax
Low Miler 16valve
« on: 10 April 2004, 10:52 »
Sorry about the subject, but if I had put "gearbox problem" no-one would have read it.
Anyway, my wives 1990 51k 16v has a problem. When you put it into first, it is just as easy to go too far and put it into reverse which is a bit of a Roger Hunt if you are rollng away from a junction. It seems that you don't have to push down the lever to engage reverse.
Can it be adjusted or is is Donald ducked? I have tried the Haynes manual but it is useless.
Thanks for your help.
Incidentally, I was in the scrappy the other day and came across a full set of BBS 15 inchers for ?60. Bought them and now giving them a tidy.
VeeDubGTI16v
Re:Low Miler 16valve
« Reply #1 on: 10 April 2004, 10:55 »
you need to replace the ball/cup selector thing (cant remember its proper name) i think.
excellent hawking on the bbs ;D
Offline The Hoax
« Reply #2 on: 10 April 2004, 11:08 »
Thanks Veedub, you are up early. There is an article in one of last year's Golf magazine issues so I wll give it a read.
Thanks a mllion for your quick response.
VeeDubGTI16v
« Reply #3 on: 10 April 2004, 11:22 »
no problem mate ;D
have you looked under the gaitor at the plastic guide which stops the gearstick going into reverse? on the left of the gearstick. might be broken also/instead.
golfvr6
« Reply #4 on: 10 April 2004, 13:42 »
There should be a plastic stop, like veedub said, on my first car , a polo, i had the same problem, select 1st and get reverse. I never bothered repairing it.
Offline RKett 16v
« Reply #5 on: 10 April 2004, 18:03 »
got the same problem on my 1990 16v you need a ball repair kit. Watch out that you get a decent kit as some of the cheap kits tend to be a bit crap on the quality side!! ;)
91' 16v        96' Daily Drive
Offline The Hoax
« Reply #6 on: 10 April 2004, 20:05 »
Thanks for all your replies guys. I ran quickly ran into German Swedish today and got the bit. I started to repair as in Golf mag and lo and behold they fail to tell you that you have to remove the heat shield and most probably drop the exhaust.
Anyway, I had loosened the mechanism from the inside and decided to put it back together to fix it when i have more time. To tell the truth I couldn't be c*****(swear word derived from Gareth or Roger). When I was finished, I tried it and it felt fine. I took it for a run and it was fine. The only thing I can think that the grease in the ball mechanism had got a bit thick with the cars lack of use over the years and stopped it working properly.
Either I have had a lucky Easter or I have just postponed the inevitable.
Thanks again guys.
Offline mk1
« Reply #7 on: 10 April 2004, 20:37 »
You have postponed the inevitable ;).
I did a 16v and had to take the exhaust off to drop the linkage out, fairly straight forward from there. Have at least half a day spare to be on the safe side.
Steve.
Offline RKett 16v
« Reply #8 on: 10 April 2004, 21:18 »
Mate theres a really good how too on a web site but i cant f**kin remember the address!!! check the old pages for topics ref crappy gears ps. can u post it cuz i cant b rsed to look my self but its on here somewhere!!! :D
