Author Topic: Kangarooing Golf  (Read 939 times)
Offline keymexman
Kangarooing Golf
« on: 17 March 2008, 17:04 »
Have an '86 Mk 2 gti 8v with a K jetronic injector fitted.
All seems to be ok until engine warms up and then I start kangarooing down the road. Seems like there is plenty of revs to use, until a load is put on and the engine tries dying. I have replaced a few rubber hoses that seemed to of perished. The RAC told me that was the problem, but every time I seem to replace something, the Golf goes OK for a few miles and then the problem stars again.
Any help would be most welcoming.
Thanks Alan.
Leon R
Re: Kangarooing Golf
« Reply #1 on: 17 March 2008, 18:20 »
Check the plugs and if they smell strongly of fuel it could be that the car is overfuelling. Alternatively it could be running too lean and not fuelling enough.
There are some checks you can quickly do, (i had a 16v so i'm going according to mine, yours being an 8v K-Jet should be similar in set-up)
First up is the WUR Warm Up Regulator, sits on the RH side of the engine and has an electric connector, 2 fuel pipes and a vac pipe going into it. This regulates fuel pressure dependent on load and engine temp. I think on the 8v K-jet it sits on the front of the block.
Unplug the connector and read off the loom if its getting 12v with ignition on.
Measure the resistance of the socket on the WUR unit (not the loom) and it should be around 22ohms.
Wont hurt to change your fuel filter if it hasn't been done to your knowledge
And, most common with VW's, coolant temp sensors. I know there are 3 on a 16v but I'm not too sure on the 8v
Offline stuckinarut
« Reply #2 on: 17 March 2008, 23:56 »
mine started playing up a few weeks ago, similar thing quikly turned into not idling cold or hot and then completely died.. turned out to be the distributor. might not be that though  :smiley:
Offline keymexman
« Reply #3 on: 18 March 2008, 00:35 »
 :smiley:Thanks I will try those idea's out. Once I retreive the car. Let you know how I get on.
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #4 on: 18 March 2008, 13:34 »
could be a spark issue also, check all connections related, i.e coil, leads, dizzy etc :)
