Author Topic: Lowering springs  (Read 1472 times)
Offline dan23
Lowering springs
« on: 17 March 2008, 14:12 »
would i get away with just putting lowering springs on my shocks as ppl tell me it can mess up the handling and over time bend the shocks, i havent got enough for a full coilover kit but i do have enought for a set of £50 springs,
help on this matter would be great
Offline Diamond Hell
  • Opinions я Us
Re: Lowering springs
« Reply #1 on: 17 March 2008, 14:48 »
What spec are the springs?
On -40mm you shouldn't knacker your dampers.
Any more than that and you should fit short stroke dampers.
Offline dan23
« Reply #2 on: 17 March 2008, 15:00 »
so if i went out and got some springs with a 40mm drop, i can just put them on in place of the old springs.
also is it hard to do or would it be best getting a mechanic to do it as my mate is a VW mechanic
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #3 on: 17 March 2008, 15:05 »
yeh 40mm springs will b fine. if you can get some gas shocks if you dnt already. fitting is easy with a haynes and bit of know how
Offline dan23
« Reply #4 on: 17 March 2008, 15:07 »
cool, well if any1 knows where some are going cheap let me know
Offline russ-vdub
« Reply #5 on: 17 March 2008, 16:26 »
search in the parts for sale, also look at peoples posts who are breakin golfs, usually tend to have been lowered :)
Offline dan23
« Reply #6 on: 17 March 2008, 16:34 »
cool, cheers for the help
Offline dan23
« Reply #7 on: 17 March 2008, 16:59 »
will lowering springs that came off on mk2 driver fit a mk2 gti?
  • Opinions я Us
« Reply #8 on: 17 March 2008, 18:56 »
They'll fit but they might not lower much the GTI was lowered in comparison to the Driver anyway.
Offline Benrevs
« Reply #9 on: 18 March 2008, 00:16 »
If you are still after springs, I have a set including shortened dampers. They were only on the car a month.....  £80 quid ish for the lot..  let one know if interested.
