Author Topic: injector question  (Read 1040 times)
Offline richard s
injector question
« on: 16 March 2008, 21:03 »
i have some injectors from a 2.0 8v seat ibiza from when i fitted bottom end but was wondering would i be better off fitting these injectors or not
cheers
Offline dan23
Re: injector question
« Reply #1 on: 16 March 2008, 21:08 »
what engine have you got in your car?
Offline richard s
« Reply #2 on: 17 March 2008, 20:33 »
its a 2.0 agg block with 1.8 pb head
Offline dan23
« Reply #3 on: 17 March 2008, 21:00 »
should be ok mate, mite pop flames a tad tho
Offline Diamond Hell
  • Opinions я Us
« Reply #4 on: 17 March 2008, 23:28 »
If they're injectors designed for use with a 2.0 8V motor and you're running a 2.0 8V motor they really should be about right, unless I'm missing something here.....
A slightly hairier cam and a flowed head with the injectors might improve performance a bit, but you really need to be running a lambda on the management, so the ECU can manage the mixture properly - for that you'd need a Euro loom and chipped ECU.
« Reply #5 on: 25 March 2008, 17:15 »
2.0 ibiza injectors wont fit the pb head, totally the wrong shape.  The PB ones should be more than good enough to run the 2.0 block though :)
Offline ben44
« Reply #6 on: 25 March 2008, 18:27 »
agg injectors are actually rated lower than pb ones! and they dont fit.  :nerd:
My signiture sucks..........................
