How easy was the gear knob to install?
Thanks,
CS
a doddle mate once you get the clip off the old one. lift up the gaitor, undo clip, pull off gearknob. Fitting is reversal of removal
the gaitor just pulls up mate; no clips holding that in. you'll see the brass clip holding the gearstick on; destroy that and pull up. you'll need to use the exisiting base as the new base is a different shape
[/quote]
Thanks - i couldn't find the original question i asked honest !
When you say destroy the brass clips, are new clips supplied?
Cheers,
CS
