Author Topic: silicon stuff  (Read 4336 times)
Dinky
silicon stuff
« on: 09 April 2004, 18:48 »
Just a quick note that i used sum black silicon stuff from Halfords(god i shud b on commission! ;)) for the rubbers on me door-had a couple of holes,wasnt leakin but wanted to patch them up anyhow,n this stuff was fab! Only bout ?4 for a little tube n done the job quite nicely-incase anyones was needed abit tlc! ;D
Easy to use n mould!
Dinky  :-*
Offline modulater
Re:silicon stuff
« Reply #1 on: 10 April 2004, 17:52 »
I would like to add that you make sure you use a low modulas, neutral cure silicone as this wont damage any paintwork or if you use it on lights the silvering on the reflectors.
Some silicones use acetate in the curing process and this sometimes causes damage.
Offline 8valvesgood
Re:silicon stuff
« Reply #2 on: 23 July 2004, 23:25 »
carplan do silmilar, dont touch it i could stick things better with my own spit.
you can find cheap alternatives from DIY stores. comes in a huge tube. black mastik
You can't polish a turd
