Author Topic: Airbag Fault  (Read 2262 times)
Offline speazzzzz
Airbag Fault
« on: 09 April 2004, 09:51 »
Was fiddling with the fusebox to get the brake lights working and now my airbag says fault, but cant find the airbag fuse, no picture on the box shows airbag ? any ideas as to what fuse runs the airbag ?
Offline GaryM
  • Gary
Re:Airbag Fault
« Reply #1 on: 09 April 2004, 14:33 »
You get the warning light when you take out the airbag fuse and put it back in.
The fuse is probably OK, you either need to use VAGCOM to reset the fault or go to a dealer who will probably charge you the earth.
Maybe post a request for anybody with VAGCOM to help you?
Im near Manchester if its any help.
2003 (53) GTI 180  | Custom Code Phase1 remap (JBS)  | Click for photo's and spec
Offline speazzzzz
Re:Airbag Fault
« Reply #2 on: 09 April 2004, 17:14 »
so does that mean the air bag is working still ?
Offline GaryM
  • Gary
Re:Airbag Fault
« Reply #3 on: 09 April 2004, 17:54 »
yes it does, its just the fault light that needs resetting
