Author Topic: gti 8v......HELP  (Read 6995 times)
Offline sijunior
  • GTI 20V Turbo
gti 8v......HELP
« on: 15 February 2003, 22:31 »
Hi everyone.
A few months ago I bought my first golf , its a MK II 8v on a  J plate, Ive got to admit  it truly is the best car I've ever driven,
As I didn't spend alot buying it I've disided to spend a few quid doing it up as its had a hard life.
I've had the engine rebuilt encluding new pistons, new piston rings , new valves and a new engine block.
The guy whom did the work told me that some one had previusly spent mega bucks tuning the engine and also fitted a race cam.( lovely)
Now the engines sorted it runs sweet, although I do have to be nice to it for 1000 miles.
It has become clear however that the car now needs a new gearbox as the gear bearings are forever wineing in gears 1, 2, and 3, I would apreciate any advice on which gearbox would suit my golf.
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
Offline richandhazel
Re: gti 8v......HELP
« Reply #1 on: 16 February 2003, 17:40 »
Have you tried changing the gearbox oil? Might find puting some synthetic oil in there will make a difference.
Offline harr1s
  • mk1 caddy and mk2 gti owner
« Reply #2 on: 16 February 2003, 18:04 »
synthetic oil from your local vdub dealer comes  highly recomended..
     Harr1s..........
Offline sijunior
  • GTI 20V Turbo
« Reply #3 on: 16 February 2003, 19:05 »
Thanks for that I'll give it a go, not sure it will do the trick though sounds to me like the bearings are on the way out,
I'll let you know :)
« Reply #4 on: 16 February 2003, 20:03 »
If that doesn't work, you should be able to pick up a good second hand one for between ?40 to ?90.
Plenty of them about.
Good luck.
Offline mk2driva
« Reply #5 on: 17 February 2003, 23:57 »
try fully sinthetic oil in it. works a treat in mine  :)
Offline Gaz123
« Reply #6 on: 25 February 2003, 22:34 »
any body know how fast the mk2 Gti goes? Im about to buy 1,but cant find the spec anywhere.
Thanx, SuperGaz ::)
