Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1045242 times)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: KELLS, BLACK G3 GTI..
« Reply #860 on: 12 May 2011, 22:22 »
why not? whats the issues matey?
Well the 8v box is rod shift and the 16v is cable shift, you need to salvage a Ibiza cupra i believe to do the swap.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #861 on: 12 May 2011, 22:23 »
had to jack it coz even with rear bumper removed the car was too low to get up the ramp haha
rod yea, but why cant i just change the whole lot out, id like to know if it is possible and what needs to be done rather than blut 1 liner replies haha
ill ask over on CGTI
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Horney
« Reply #862 on: 12 May 2011, 22:23 »
8v is rod change and cable clutch system, 16v is cable shift and Hydrolic clutch. These two systems are quite different and have different peddle boxes as well as the gear change and fluid/cable differences. It is doable but it would be a right pain and would make the 16v a pain to maintain in the future plus any savvy buyer would be put off by all the 8v stuff in it.
Nick
Offline F17BAD
« Reply #863 on: 12 May 2011, 22:25 »
Nick
pedal box is exactly same mate
all the 8v stuff, its just a gear box, iv seen folk use this box in conversions on mk2 with ABF, is it really that hard a job to do. i just want the car ro run about in
 p.s hydro set up off in black one
« Reply #864 on: 12 May 2011, 22:28 »
The pedal box isn't teh same as Horney mentions due to the 8v having a cable operated clutch
Offline Horney
« Reply #865 on: 12 May 2011, 22:29 »
Humm maybe the MKIII 16v still has a cable clutch then, was pretty sure they were hydro. Been a while since I had my head under a 16v so I'm sure some one else will confirm the clutch type. If it is a hydro one th epeddle box will be different to drive the cylinder.
Folks use the ABF gearbox in MKII's as it's stronger than the 8v one and the cable shift means you can mount the shifter up high in a track car.
Nick
« Reply #866 on: 12 May 2011, 22:30 »
The mk3 16v clutch is definitely hydro operated.
Offline F17BAD
« Reply #867 on: 12 May 2011, 22:30 »
been told its the same bar a bit on it which u blank off or something,
Originally Posted by kells
So can i not use the 16v cat at all ? do i need to use the pedal box from the 16v too ??
im going to remap it also once its all fitted
All Mk3 pedal boxes are the same but you will need to add the hydro clutch setup to yours if your using a 16v box.
__________________
Offline lemski
  • 16v
« Reply #868 on: 12 May 2011, 22:31 »
16v are hydros just to confirm. Kells whens the work starting on this beast properly anyway?
Offline F17BAD
« Reply #869 on: 12 May 2011, 22:32 »
what do i need to do then to rock the 8v box or is it a deffo no go
work has started mate, see pics, main work starts saturday, i collect my BAM sat morning as its still in a seat cupra R thats been wrote off
