Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1045210 times)
Offline Bellend
Re: KELLS, BLACK G3 GTI..
« Reply #560 on: 30 December 2010, 21:05 »
Did you use loctite on the cailper bolts.
yeah i got locktite on those plue the carrier bolts
That is the carrier that's moved tho?  :huh:
Where all my moneys went.
Offline AudiA8Quattro
« Reply #561 on: 30 December 2010, 21:06 »
You shouldn't need loctite on the carrier bolts, they are tight.
The caliper bolts need loctite.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #562 on: 30 December 2010, 21:10 »
we were bloody shocked TBH
Re the Rad, my bad really, i had developed a leak, and was topping up on water till i got round to fitting the new Rad, guess too much water in the system, the one night of -12 did the obvious
all good results in the end tho, car is now running to perfection once again, its also had a service with genuine VW parts, oild etc... all good at the mo
tomo ill be giving it a good clean..
also got this kit as one of my gifts at Xmas... cant wait to use it, gonna go on a quick course before i use it tho, just so i can learn the right way..
http://www.monzacarcare.com/machine-polishing-3/dodo-juice-rotary-starter-polishing-kit/0/
@audi quattro, if thats the case why do the bolts you get with genuine pads have locktite on the threads when u buy em  :wink:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline F17BAD
« Reply #563 on: 30 December 2010, 21:13 »
Yeah the whole lot had moved, the bolts that are allen key ones which hold the carrier to the car were the ones missing, i also dab a lil sealent on the 2 13mm bolts that hold the caliper centre to the carrier.. if this makes sense
Offline Bellend
« Reply #564 on: 30 December 2010, 21:15 »
I see what you were saying. Lucky though, sharp corner and not expecting it.  :lipsrsealed:
Yeah mate, they are the calliper bolts, which need loctite.
The carrier bolts don't apparently which when thinking  about it most don't.....
Offline F17BAD
« Reply #565 on: 30 December 2010, 21:18 »
i know the bar stewards were tight as a nuns ass hole
the caliper made a nice grinding mark on the inner wheel, thank got i have the winter rims on and not my porkers
« Reply #566 on: 30 December 2010, 21:42 »
As Bellend just said, the caliper bolts need loctite, they are only about 20lb ft.
The carrier bolts(allen heads) are 60ft lb(i might be wrong), but they are tight and don't need loctite.
« Reply #567 on: 30 December 2010, 21:48 »
Correction the carrier bolts are 65nm or about 48lb ft, if tightened with a torque wrench, they shouldn't come loose!!
Offline F17BAD
« Reply #568 on: 30 December 2010, 21:51 »
ahh i see, yeah mate thats what i meant, a bit of confusion their, it was the 2 Allen head bolts which were gone (the ones that dont have locktite as standard)
they very extreeeeeeemly tight around 3 month ago, as i hammered the allen key - to nthe point i was worried id not get them off again  :grin:, i could no way get my torque wrench in that tight area
Offline Diamond Hell
  • Opinions я Us
« Reply #569 on: 31 December 2010, 09:50 »
So you over-tightened the bolts and stretched the threads, which is why they came loose.
I've had a rear caliper carrier bolt come loose on a test run in my Golf before - makes an almighty racket when it comes loose - every time you let off it goes 'clonk' into the wheel.  You must have had some bangin' choons on in your car not to notice it happening.
As for progressively thinning your coolant down to water through winter oop norf.  :rolleyes:
