Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1045210 times)
Offline Diamond Hell
  • Opinions я Us
Re: KELLS, BLACK G3 GTI..
« Reply #550 on: 16 December 2010, 15:53 »
small new mod, new led modification iv done, these illuminate the gearstick/cubbyhole are really well without distracting you in the night, similar to what you find in the new BMW's
And tractors since about year 2000.  I think that's a more appropriate comparison to draw.
Although the tractors are far more sophisticated than this old barge.
wont be around much to answer to this post, so please dont think im been ignorant
QED.  Answers not required.
Offline Jimp
« Reply #551 on: 16 December 2010, 15:58 »
Nice one on the interior lights. Reminds me of the W8 light mod on mk4s. The same lights are in my mk5 as standard, same shade of red too. They look so cool  :cool:
Not low enough mk5
Not on the road enough mk3
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #552 on: 16 December 2010, 16:13 »
Yeah they look cool at nite, really good little mod this, i didnt realise the mk 5 had them, nice touch  :cool:
As for a tractor been more sophisticated, id say one of those could be much more sophisticated than most cars on the road...
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline SoundillusioN
« Reply #553 on: 16 December 2010, 16:20 »
  :lipsrsealed:
Offline F17BAD
« Reply #554 on: 30 December 2010, 20:54 »
Had a slight issue the other night with the rear brakes..
hit a bump in the road at 40mph and the rear brakes locked up, handbrake was jammed on, drivers side rear disc was glowing orange like a Le Mans 24HR car  :laugh:, and the amount of smoke that was coming off it i thought the car was gonna set up in flames
Second mare of the night was the car not fitting on the tow truck greenflag sent, which was annoying because they told me the name of the garage who were going to recover me, and i know only one of their trucks fits my car on due to how low it is.. Anyhow long story short they came in a regular tow truck, i couldn’t be arsed to f**k about so I removed the lower splitter and all was good  :cool:
Myself and Ben (Ben victors off here) inspected the car the morning after to find this on the rear passenger side
Spot the problem....
(for those less blessed amongst us the calliper should sit at around the 1 o clock position)
Also the sh!t guard that sits on the hub was like this
The reason???  Well the bolts which hold the calliper on the hub were gone!!!!  No damage, no fecked threrads, just complete gone as tho they had been removed; now i know these were super tight as i hammered them on a few month back...They are the 2 Allen key bolts.
I also had a overheated problem due to a frozen RAD on the night we had a -12 temp... this was the nail in the coffin for my already leaking radiator....cracked...big time
So we  fitted a new one, no pics of the new on but here is the car in prep for removal of old unit, we managed to remove/replace with the slam panel in situ which was a bonus, refilled the system with 50/50 mix of VW G12 Plus, and fitted a new heater resistor..
car heater/coolant system runs like a charm as do the breaks, we were lucky enough not to have warped a disc, one of the pads was destroyed so we changed those out for a new set
Last thing done was wiring in my puddle lights in my doors, we did Bens car too, this is a cool mod
trip to the car grave yard to find a MK4...
and here they are, these are lit, bright so hard to get a decent pic but you get the idea, basically just like on a mk4 gti
« Last Edit: 30 December 2010, 20:56 by F17BAD »
« Reply #555 on: 30 December 2010, 20:56 »
Did you use loctite on the cailper bolts.
Offline Bellend
« Reply #556 on: 30 December 2010, 20:58 »
As Wayne said.
I absolutely f**king hate Loctite but this is why I force myself to use it.
Can't really think why else it would have happened. :undecided:
Where all my moneys went.
Offline F17BAD
« Reply #557 on: 30 December 2010, 20:58 »
yeah i got locktite on those plue the carrier bolts
Offline Bellend
« Reply #558 on: 30 December 2010, 21:01 »
Very strange.  :huh:
It's impossible to get to them without removing the car/jacking them up really, isn't it?  :undecided:
Lucky though!
How comes it froze? Topping it up with water?
Good results all roundish I guess.  :grin:
« Reply #559 on: 30 December 2010, 21:03 »
Very odd then.
