Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1045243 times)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: F17BAD G3 GTI. S3 TURBO
« Reply #2260 on: 16 December 2011, 19:30 »
not the edges, the checker pattern!
Hmm maybe, ill see how it gets on  :smiley:
as i say, this is a Mule :smiley:
Not no ordinary GTI....
www.mixcloud.com/kells/
« Reply #2261 on: 16 December 2011, 20:40 »
 :undecided: on one hand the plate will no doubt help but on the other hand have you now not made the problem worse by making the sump even lower to the road.
Offline F17BAD
« Reply #2262 on: 16 December 2011, 20:42 »
theirs only 5mm more than standard
Could not have a full undercover plate for the reason you mention
The INA sump i like is taller than standard but stronger. mine is now the same but not as tall as the INA version... so we will see, only time will tell
Offline SoundillusioN
« Reply #2263 on: 17 December 2011, 16:46 »
My thoughts exactly and then some... As well as what's already been mentioned my problem is this:
5mm is a lot in your case, plus the thickness of the protruding welds that are now easier to catch in area's that weren't before now.
The sump plug is vulnerable
Looking at the new one surely this area has the exact same risk and is even more likely to be caught now.
 :undecided:
Offline F17BAD
« Reply #2264 on: 17 December 2011, 17:07 »
lots of negativity on this forum as usual lol :grin:
Offline benvictors
  • bgk Tuning - coming soon!!!
« Reply #2265 on: 17 December 2011, 17:13 »
Think the idea of the plate is to stop the sump from cracking/splitting, if.... sorry, when it bottoms out  :wink:
« Reply #2266 on: 17 December 2011, 17:18 »
Nooooo not at all, there is no point just saying how amazing it is if there are honest doubts on how effective this will be. The effort put into this is good and I hope for your sake it works but there is no denying that this is more likely to catch the ground over the standard one that's all. Yes it will be stronger but the extra strength appears to come at a price.  You may as well of raised the front by 5mm (which i know you don't want to do) which would have given 10mm more clearance than what you have now.
« Last Edit: 17 December 2011, 17:24 by SoundillusioN »
« Reply #2267 on: 17 December 2011, 17:22 »
Yeah I get that. But it's more likely to catch now and if it catches on something nasty then I dread to think how it would react now the base is more rigid...  I just have a phobia of things catching the ground at speed.
Offline benvictors
« Reply #2268 on: 17 December 2011, 17:29 »
I know what ya saying Shaun, I think Brad just needs to keep a better look out for pot holes  :grin: :grin:
« Reply #2269 on: 17 December 2011, 17:38 »
A big problem in Leeds isn't it?... Although my experience on Sheffield roads is far worse.  :laugh:
