Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1045221 times)
Offline SoundillusioN
Re: F17BAD G3 GTI. S3 TURBO
« Reply #2250 on: 15 December 2011, 21:49 »
On the Caddy Conversion - the mounts we have had made, tilt the engine backwards, i had to chop parts of the bonnet off for it to clear the Throttle body  (this stuff should really be kept in the Caddy build tho )
I will be updating the Caddy thread after W/end, but theirs some pics of the engine in the bay already up
Sorry, you mentioned the Caddy in here, you know how it goes.  :grin:
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #2251 on: 15 December 2011, 22:14 »
 :grin: :grin: :grin:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline F17BAD
« Reply #2252 on: 16 December 2011, 18:10 »
Got my Strengthened Sump back, and its now fitted to the car.. didn't get picks of it fitted as the Phone battery died, will get some on monday this when I'm next with the car.. left it in a warehouse till monday for the sealant to set
anyhow, 5mm plating of some of the strongest steel around, can't remember what he said it was but it won't rust and will take a lot of beatings  :grin:
He also filled in all the cracks i had from the inside before he did the plating.
Im well please with this and look forward to giving it a good test..  dropping 2 more Sumps off on Monday
i only waned one small strip  just in front of the sump plug area of about a inch wide as its only this part that takes the beating form the road due to the angle of how the sump sites. but he has made the plate go right over on to the shallow half, which is a bonus.
Some pics
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #2253 on: 16 December 2011, 18:15 »
so its not just boggo steel checkerplate ??
Looks really good i hope it helps mate
Offline F17BAD
« Reply #2254 on: 16 December 2011, 18:16 »
no mate coz that will rust.. he said a name.. ill ask him and let you know.. although I'm not too bothered about aesthetics to be honest.. this is the Mule Sump  :grin:
VeeDubGTI16v
« Reply #2255 on: 16 December 2011, 18:17 »
what's the idea behind checkerplate over flat steel?
Offline F17BAD
« Reply #2256 on: 16 December 2011, 18:28 »
did you see earlier in the thread??  the sump has been hitting the floor and worn through, resulting in loss of all oil
this is to help aid strength.. and thats all
VeeDubGTI16v
« Reply #2257 on: 16 December 2011, 18:39 »
i mean as in reinforcing with plain sheet over checkered sheet
my thinking is that whatever scrapes on the sump will now catch on the checker and cause a bigger impact! might be worth grinding the raised bits off, at least it will just scrape then
Offline F17BAD
« Reply #2258 on: 16 December 2011, 18:42 »
did think of grinding the edges but didn't want to weaken it, TBH, its not bad at all, 5mm over standard to be exact lol.. and the bits that catch are not the parts that are where the welds are, so grinding down isn't really going to help
Car is too low, but i wanna keep it this way.. its my bad if it happens again but I'm interested to see how this fairs before i do any more mods to it
VeeDubGTI16v
« Reply #2259 on: 16 December 2011, 19:10 »
not the edges, the checker pattern!
