Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1045575 times)
Offline T_J_G
Re: F17BAD G3 GTI. S3 TURBO
« Reply #1320 on: 16 June 2011, 12:33 »
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #1321 on: 16 June 2011, 13:55 »
My custom Decat Section has arrived
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline pablo64
« Reply #1322 on: 16 June 2011, 14:20 »
Kells must have missed vid, anyway just looked, sounds real sweet even with no  exhaust, brilliant job you've, pipe looks  :cool: , you going to fit it then wi you saying you dont need one, good luck with MOT tomoz matey  :smiley:
Offline F17BAD
« Reply #1323 on: 16 June 2011, 14:28 »
Cheers mate, fitting it tonight, then ill be test driving the car and MOT tomo
the video is here for those who missed it
First time running - no exhaust
http://www.youtube.com/watch?v=-EVRbuDQ5Kg
Offline Sam
  • Sam I am
« Reply #1324 on: 16 June 2011, 14:31 »
Stick with no zaust  :smiley: :smiley:  :cool:
Offline F17BAD
« Reply #1325 on: 16 June 2011, 14:33 »
hehe wish i could  :evil:
Offline mellow yellow
  • A Driffield Dubber!
« Reply #1326 on: 16 June 2011, 15:04 »
good luck with the mot kells, hope it flies through!
Offline Misky
  • MK3 16v GTI FTW!!!
« Reply #1327 on: 16 June 2011, 15:13 »
I have every faith this beauty will pass without a single problem! As Brads high standard of work and persuit of perfection will not let anything slip  :cool:
MK3 16v GTI FTW!!!
Offline F17BAD
« Reply #1328 on: 16 June 2011, 15:34 »
Cheers for that :cool:, everything should be ok, just the no cat issue. the Cat thats coming from the states is currently "been processed" my UK Customs
so if we do need it, it should not be long till we have it.. i hope i dont need it tho, would rather run with no cat
Offline Sam
  • Sam I am
« Reply #1329 on: 16 June 2011, 15:42 »
Take the test, its will fail for no cat then you have x amount of days to have a mega cheap re-test which will simply be has it got a cat... yes... PASS! Also this would make you aware of any little niggles that the car may have.
