Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1045248 times)
Offline robz
Re: F17BAD G3 GTI. S3 TURBO
« Reply #1300 on: 14 June 2011, 20:28 »
look forward to the results then!
Offline CCGTI
  • Fueled Society
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #1302 on: 14 June 2011, 20:58 »
i was offered some of these from where my engine came from, but i dont think they fit behind 16" rims
Not no ordinary GTI....
www.mixcloud.com/kells/
« Reply #1303 on: 14 June 2011, 21:11 »
They won't 316mm is the biggest you can get behind 16" rims.
312mm set up is really good however, they have lots of feel.
Offline tshirt2k
  • Been there...Done that...
Re: KELLS, BLACK G3 GTI..
« Reply #1304 on: 14 June 2011, 22:03 »
I'd advise making yourself a leak tester for those boost pipes. Jubilee type clamps don't usually clamp hard enough. I had major leaks when I first did mine and was using mikalor type clamps. You need to pressurise it up to around 20psi to make sure its leak free. As that's what a remapped one usually boost at.  :wink:
which type am i best switching to? ill get whatever is best?
Mikalor are the best type. Like these. Just get size you need.
http://cgi.ebay.co.uk/PACK-4-Mikalor-W2-Supra-Clamps-59-63mm-Stainless-/390282095170?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5adea02a42#ht_3220wt_689
Mk3 ABF 16VT Megasquirt V3
Offline cняis
« Reply #1305 on: 15 June 2011, 13:36 »
Re cats and MOT requirements, I've heard nothing at work regards moving the date from 92 to 94 so i'm interested to see the outcome  :smiley:
Offline robz
« Reply #1306 on: 15 June 2011, 13:40 »
so am i as wanna mot mine next month :D
Offline F17BAD
« Reply #1307 on: 15 June 2011, 13:57 »
will be interesting, really hope it passes as id prefere to run no cat.. more power  :evil:
we are gonna finish up fitting the new oil sensors tonight and build front end up fully and tomo ill have the small bit of pipe needed to fit the exhaust and then we will give it the first ever road test. The guys who made the downpipe have very kindly made it for me out of St/ST  - Company is Trackslag.com...  check these guys out
Offline robz
« Reply #1308 on: 15 June 2011, 14:05 »
man im getting excited, you must be wetting yourself haha
Offline F17BAD
« Reply #1309 on: 15 June 2011, 14:26 »
it still feels like a dream mate..
spent a long time planning this to perfection an got a boat load of stick, sly digs and bollox on here for doing so, but i stuck to my guns im glad i did it the way i have because i would not change a thing about the conversion. im over the moon cant imagine what its gonna be like to drive
so much more to come with this car too...
