Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1044951 times)
Offline tshirt2k
  • Been there...Done that...
Re: KELLS, BLACK G3 GTI..
« Reply #1080 on: 27 May 2011, 17:59 »
great info guys
need to sort the tubing out, tshirt what do u actually recommend ?? my IC is the same as Dans
Recommend , as in what? Size, material?
Look at the boost run on mine, it will be very similar to your layout. Due to using TT/S3/cupra inlet.  I used 57mm stainless tube. I also used a toyosport ebay IC . Going too large on the tube can be harder to run due space needed.
Mk3 ABF 16VT Megasquirt V3
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #1081 on: 28 May 2011, 12:21 »
did you use the tubing that came with the IC ??
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline tshirt2k
« Reply #1082 on: 28 May 2011, 15:07 »
No. Didn't buy a kit. Bought all bits separate due to not wanting be left with any bends etc that I didn't need. Plus stainless was easier for me to work with.
Offline F17BAD
« Reply #1083 on: 28 May 2011, 18:58 »
think im gonna do same, make our own pipes up
couple more bits collected today from dealer
but most part of day was spent with ben removing ABF Gearbox and sh!t and replacing it all with the 8v set up
here she is, awaiting the magic treatment from me, which im gonna start after my tea
more work tomo - gotta get green car built back up because its sold
Offline mark-mk3gti
« Reply #1084 on: 28 May 2011, 19:14 »
what u doing to the gearbox? rebuilding it your self? :) how much work is involved in that..
god speed........
Offline F17BAD
« Reply #1085 on: 28 May 2011, 20:57 »
we are doing everything ourself
gearbox will look like new once done... :cool:
as for rebuilding gearboxes you can buy a kit for about 90 quid
Offline golf-sib
  • Турботазик
« Reply #1086 on: 29 May 2011, 11:20 »
Here's the tool I used:
http://cgi.ebay.co.uk/Pipe-Tube-Beading-Tool-/190529519802?pt=UK_Hand_Tools_Equipment&hash=item2c5c71c0ba
Its designed for pipes upto 2.5", brilliant tool, you use it in a vice. The bead is down to you how much you want it pressed, big lip or just a bulge as your in the control of the vice. Its fine to use on stainless piping, as I cut down one off the standard stainless pipes and beaded it to have an additional T-piece rather than buying odd bits that I could save money on (same thing you can do with the standard silicon, slice it up into pieces, lengths or angles you may need, its money in your pocket). Also the 18 swg thickness limitation can be ignored for alluminium due to it being softer and I succeeded on a bigger swg size in aluminum pipes to bead.
Here's the device in action:
The t-piece in stainless I was on about:
The lip it produces:
You doing any thing additional like catch can install, making additional brackets, cleaning injectors?
Hope this helps
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline F17BAD
« Reply #1087 on: 29 May 2011, 12:43 »
Ben is gonna fab up some brakets we will need for certain stuff yeah
Injectors cleaning ?  what do you mean sent away to be cleaned. If so i dontthink dso the engine is less than 40k and they look brand new do the injectors
Gearbox has come up well, its had a recent rebuild so i wont need to do that  :smiley:, jsut gotta paint it up now but thats a job for tomorrow because im DJ'ing at a courtyard event at 2 o clock then off out for tea with the other half
Will pop up pics of the gearbox tomo once iv finished with it   :cool:
that tool looks wicked mate. where are you from ??
wi
Offline golf-sib
  • Турботазик
« Reply #1088 on: 29 May 2011, 14:17 »
I'm from kent/london really, the thing says northfleet but I'm around the wellin/ bexleyheath dare DA16/DA9 as I have not yet moved house yet.
Try registering to a locost/kit car forum such as this: http://www.locostbuilders.co.uk/
The guys on there have a wealth off knowledge and will help out majorly with a few beer tokens if they are local.
I have a cheap ultrasonic cleaner, my engines only now upto 75k and the idle feels smoother after the clean, the lads on the audisport forum are on this and are seeing improvements in idle and response on engines as little as 50k... But I'm no expert, while its out why not give it a clean and you can inspect the o-rings as well. I had two nasty o-rings on my injectos when I first took them out at 65k so it does not hurt to have a look I suppose.
1.8T AGU..
R135
  24
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #1089 on: 29 May 2011, 16:32 »
Sexy tool.  :smiley:
