Author Topic: Wheel Refurb  (Read 5098 times)
Offline Wizzkidd
  • Big fish, little fish, cardboard box \m/
Wheel Refurb
« on: 13 March 2008, 22:40 »
Hi guys as title states i wana do a mini refurb
bought some pretty standard alloys from ebay there pretty badly scuffed and 1 has a title dent in.
any ideas on bit of refurb? any products?
Cheers WK
Offline Conker
Re: Wheel Refurb
« Reply #1 on: 23 March 2008, 20:25 »
Theres not many options to choose from. In order of difficulty...
1)  A really good scrub with a strong degreaser, and maybe a clay bar for embedded brake dust.
2)  A quick "ghetto" respray with DIY wheel paint.
3)  Sanding, filling, spraying.
Errr.... Or just pay between £25 and £45 per wheel and have them refurbed.  :tongue:
Offline mark3valver
Re: Wheel Refurb
« Reply #2 on: 04 April 2008, 08:47 »
I would do them yourself mate.... its good thing to learn and really isn't that hard, especially if they are a simple desing (ie not bbs!!!!)
Start by sorting out any big kerb marks round the edge of the rim - best with the tyre off. sand/file/ what ever you have to do to get it smooth!!!
Then sand the whole wheel with something like 120 grit.... if there are any chunks missing on the face of the wheel then use P38 body filler from halfords to fill - it is easy sand (apparently!!)
once you have sanded any repairs flat with the 120, go to a higher grade (poss 180/240) and give it all a good sand. At this point if the surface is still obv keyed from the higher grit paper (ie if you painted it you would see the scratch marks) then you need 2 types of primer - high 5 from halfords is a high build primer that will go on quite thick and go over any little marks....
sand this back with 240 or higher until totally smooth then use a normal silver primer.... you can sand this back once dry but if you have done a good job before hand you can just top coat over the top. I would do a couple of coats of primer followed by 2/3 coats of top coat and then maybe 3 coats of lacquer...
sounds a lot but remember a 'coat' takes roughly 30 seconds..... best to prep two wheels at a time and then paint at the same time to speed things up..... you will probably find you do 5 wheels, as by the time you have done four you will have learnt a lot and want to re-go over the first wheel!!!!
good luck, its quite rewarding - might do a how to guide when I do my next wheels
want a pair of raceland buckets with model specific subframes for £150 delivered? go here
http://www.golfgtiforum.co.uk/index.php?topic=83910.0
Offline boneybradley
  • Back in a Mk3...
Re: Wheel Refurb
« Reply #3 on: 04 April 2008, 08:51 »
have a look at my guide....http://www.golfgtiforum.co.uk/index.php?topic=82219.0
i bought a mutti pack of wet and dry.. alltough medium git is possibly best for starters and the rough stuff can damage the alloy! and I used normal auto paint and primer
