Author Topic: knackered diff  (Read 1144 times)
Offline cняis
knackered diff
« on: 13 March 2008, 22:34 »
what are the characteristics of a knackered diff? just wondering really.
also what happens if you have a knackered diff pin?
 :tongue:
Offline leavingeasy
Re: knackered diff
« Reply #1 on: 14 March 2008, 11:26 »
it wears a hole in the diff- common problem.
coming to some armco near you soon.....
Offline cняis
Re: knackered diff
« Reply #2 on: 14 March 2008, 11:53 »
what are the symptoms?
Offline Diamond Hell
  • Opinions я Us
Re: knackered diff
« Reply #3 on: 14 March 2008, 11:55 »
In dramatic cases the crownwheel machines it's way out of the case.
Known as 'riding up with wear'  :grin:
Offline Organisys
  • Old and Slow...
Re: knackered diff
« Reply #4 on: 14 March 2008, 12:27 »
If a pin does let go, they quite often blow a hole through the gbox.   :laugh:
Offline davidhawkins_78
  • Valver Bad Boy
Re: knackered diff
« Reply #5 on: 14 March 2008, 12:45 »
I can back this up!!  :cry:
I've had it happen twice now and both times made a fat hole followed by gearbox oil flying everywhere!
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline cняis
Re: knackered diff
« Reply #6 on: 14 March 2008, 12:49 »
so the occasional knock i get whilst pulling away hard is probably not a diff problem then?
  • Valver Bad Boy
Re: knackered diff
« Reply #7 on: 14 March 2008, 12:56 »
Nooooooooooooo and be thankful!
More likely to be a bearing, bush or engine mount. Start of with a static check with the wheels off to find any unwanted 'play'.
Dave.
Offline Organisys
  • Old and Slow...
Re: knackered diff
« Reply #8 on: 14 March 2008, 12:56 »
could be any number of things.
top mount
CV joint
Loose Steering Rack
Ball Joint
Split wishbone bushes
loose stut to hub bolts?
edit: or engine mount as above.
 :smiley:
Offline cняis
Re: knackered diff
« Reply #9 on: 14 March 2008, 14:48 »
top mount
CV joint
Loose Steering Rack
Ball Joint
 :smiley:
thanks guys  :cool:
