Author Topic: Blown Head Gasket  (Read 1979 times)
Offline slowgti
Blown Head Gasket
« on: 13 March 2008, 01:03 »
Im guessing that water bubbling out of the reservoir cap when the engine starts warming up is a sign of head gasket failure? are there any more obvious signs? is over heating one of them? i dont want to rip the head off for no reason, i just got it running good..
Offline Neaty
Re: Blown Head Gasket
« Reply #1 on: 13 March 2008, 01:06 »
is there yellow gunk under the oil filler cap? thats usually a sign of a head gasket going?
Offline slowgti
« Reply #2 on: 13 March 2008, 02:03 »
na its just got a spot of oil on it. ill fully drain it soon and inspect it properly then. is it possible to have a blown head gasket without water in the oil?
Offline Neaty
« Reply #3 on: 13 March 2008, 02:05 »
to be honest mate, i am not sure. Another one to check is on the block, where the head meets the bottom end, is there water weeping from the join?
Offline slowgti
« Reply #4 on: 13 March 2008, 02:14 »
na mate the only sign i have is water randomly bubbling out of the radiator cap, and the water temp is known to raise at the drop of a hat. is it possible is has only cracked between the cylinder and the water jacket?
thanks
Offline paultownsend
« Reply #5 on: 13 March 2008, 08:45 »
get a new expansion cap from vw
this was happening to mine as it wasnt venting properly
Offline filthy
« Reply #6 on: 13 March 2008, 08:49 »
Do a compression test- that will give you a definate answer
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
Offline Village Idiots
« Reply #7 on: 13 March 2008, 09:11 »
Garages can do a test on the coolant to see if it's contaminated. Takes a couple of minutes so not expensive.
Offline Tristan 2.0 8v
« Reply #8 on: 13 March 2008, 09:14 »
Yup. Try a new cap, but I expect it's the gasket. Look on the bright side though, at the same time you can do the stem seals, decoke the head lap the valves in etc. Cost of parts is only about £150 and that would include a skim and cambelt change!! It's an easy enough job to do yourself (minus the skim of course) or pay someone else to do it for about £300 ish.
Offline Conker
« Reply #9 on: 13 March 2008, 09:42 »
I'd agree with that.
Unless you've got other signs of HG failure don't worry, e.g. loss of coolant, oil in water, mayo in oil, overheating, white smoke or black smoke, or any of the above!
