Author Topic: rocker cover earth?  (Read 2197 times)
Offline paultownsend
rocker cover earth?
« on: 12 March 2008, 14:02 »
im sorry but my cameras broken, so il try explain the best i can
there is a flat plastic covered lead that attatches to a thin plate on the rocker cover, and seems to dissappear to the area of the coil.
what is this for as during my bvh head it has snapped
Paul
Offline russ-vdub
  • Once a Dub, Always a Dub
Re: rocker cover earth?
« Reply #1 on: 12 March 2008, 15:26 »
its only for protection really, not essential to have on .. dunno what you mean by "bvh head" tho?
Offline Diamond Hell
  • Opinions я Us
« Reply #2 on: 12 March 2008, 15:35 »
Don't run the car without it - you can get odd earthing across the vehicle and it can pop the ECU.
« Reply #3 on: 12 March 2008, 15:35 »
oh sorry, big valve head!
excellent, so i can earth it anywhere really?
Offline russ-vdub
« Reply #4 on: 12 March 2008, 16:36 »
earth is an earth at the end of the day.. just make sure you get a dvm and check that it is actually grounding
  • Opinions я Us
« Reply #5 on: 12 March 2008, 16:40 »
Quote
No it's not.  If you don't earth the engine correctly you can get voltage differences across the body which will result in the ECU seeing wierd readings and possibly voltage above what the circuitry is designed to.  Then you get dead ECUs.
Earth it as it came out of the box and it'll work properly.
Offline russ-vdub
« Reply #6 on: 12 March 2008, 16:45 »
where are voltages running through the rocker cover?? these are protective earths, thats all
  • Opinions я Us
« Reply #7 on: 12 March 2008, 16:48 »
It's earthing the engine to the shell.
Is it worth taking the risk of frying the ECU?
Offline russ-vdub
« Reply #8 on: 12 March 2008, 16:55 »
agreed its not worth risking it but theoretically you can earth it anywhere on the chassis as all earths go to the chassis at the end of the day
Offline syncrogolf2
« Reply #9 on: 12 March 2008, 16:57 »
If you have a carburettor engine then this earth is not that important, but with a GTI digifant injection system this connection has an earth cable dedicated to the ECU and running about with this connected is just an accident waiting to happen, usually when starting up and the starter motor is pulling a lot of current & the usual earth cant keep up, then it can & will leave the ECU stone dead and unrepairable!
BTW this is not just a protective earth but actually part of the ECU injection & knock sensor circuit.
« Last Edit: 12 March 2008, 16:59 by syncrogolf2 »
