Author Topic: MK3 GTI 16V REVS..........  (Read 1191 times)
Offline vdub virgin
  • If it aint broke....dont fix it!!
« on: 11 March 2008, 17:36 »
hi, can anyone help with this?
when you rev the engine then take your foot off the accelerator the revs very slowly fall back down,and not drop down as normal,very annoying and makes the k&n sound sh*t wen you rev it up!
ive tried oiling the throttle cable in case that was sticking and cleaning the butterfly in the throttle body but to no avail :sad:
anybody no wats causing it?
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
Re: MK3 GTI 16V REVS..........
« Reply #1 on: 11 March 2008, 19:36 »
Have you replacerd vac lines ..?, cheap to do and could make the difference.
Offline vdub virgin
« Reply #2 on: 12 March 2008, 12:33 »
no i havnt,thanks ill get sum silicon tube n replace em,
thanks! :smiley:
Offline DaveGTiMK
  • 16v MK3 GTi
« Reply #3 on: 12 March 2008, 14:22 »
mine does this.
Check for leaks around the air box pipes etc, replace or clean any old ones
But from what I have been told this is fairly normal for the 16v.
Gonna hangout with the wangout
Offline MK3GTI_16Valve
« Reply #4 on: 12 March 2008, 23:49 »
Sounds normal to me, mine does the exact same, always has done
Offline ToddyGTi
  • I Love GTi's
« Reply #5 on: 13 March 2008, 12:30 »
Had the same problem, turned out to be a vacuum leak on the pipe from the inlet to the fuel pressure regulator.
Part of the Booty Club
Offline vdub virgin
« Reply #6 on: 13 March 2008, 13:48 »
wheres the fuel pressure regulator? :undecided:
