Author Topic: where to buy vacuum hoses  (Read 920 times)
Offline smithysmoo
« on: 11 March 2008, 13:44 »
Can't find any leaks but going to replace to be on the safe side. Where do you get the correct bore hoses from.
Offline russ-vdub
  • Once a Dub, Always a Dub
Re: where to buy vacuum hoses
« Reply #1 on: 11 March 2008, 13:46 »
scrappy yard. or vw stealer.
to be honest mate if you wana make sure they aint leaking, put them in a bucket of water, hold off one end with your finger inside the water and blow down the other end. you'll see any leaks in the pipe instantly.
Offline smithysmoo
« Reply #2 on: 11 March 2008, 13:48 »
Good idea mate will check them that way and see if I need new ones, prob get them new from vw if I need any that way I know for sure.
Offline russ-vdub
« Reply #3 on: 11 March 2008, 13:52 »
yeh vw will be able to order you some lengths in. glad to help :)
Offline smithysmoo
« Reply #5 on: 11 March 2008, 16:21 »
Have seen that on there, its the right bore then...How much did you get to replace yours???
Offline paultownsend
« Reply #6 on: 11 March 2008, 16:55 »
i got 2 metres and thats covered to the mfa, to the airbox and all of the tb
Offline smithysmoo
« Reply #7 on: 11 March 2008, 17:04 »
cheers might just change them for the sake of a fiver then.
