The garage
help with codes
Topic: help with codes (Read 1909 times)
4 cylinder 8v fuel injected 205 killing machine
help with codes
08 April 2004, 00:03 »
please help me where is my engine code its a golf gti mk2 h reg 8 v
i need it to order a new down pipe today
thanks in advance for any help given
Blue MK2
Guest
Re:help with codes
08 April 2004, 09:08 »
u mean like 'PB' on digifants?
mk1
2ltr16v turbo (now with programmable EFI)
Re:help with codes
08 April 2004, 18:17 »
Assuming it has the original engine, check the sticker in the boot on the rear panel.
Steve.
http://www.geocities.com/mk1turbo16v/golf_turbo.html
modulater
Re:help with codes
09 April 2004, 12:15 »
The engine number is located at the front of the block below the joint between block and head.
Also check the barcode sticker on your cam belt cover if you still have it as this has the engine number on it.
Re:help with codes
12 April 2004, 14:19 »
cheers found it it was pb
The garage
help with codes
