Author Topic: door hinge ajustment  (Read 1576 times)
Offline gtiscott
« on: 10 March 2008, 15:45 »
hey guys, is there an ajustment on the hinge that lets you pull door further in at the top, i seem to be getting a lot of wind noice and looking at the door when closed it seems to stick out slightly at the top.
cheers
Scott
Offline Pete Taylor
Re: door hinge ajustment
« Reply #1 on: 10 March 2008, 18:25 »
The can be done by loosinging off the lower hinges and putting shims in. A much better fix is to get new half hinges from VW. Think they're about £7 per half hinge
Offline gtiscott
« Reply #2 on: 10 March 2008, 19:41 »
thanks Pete, so do i only need to buy half of the hinge? and is it just a matter of swapping old for new?
cheers
Scott
Offline Pete Taylor
« Reply #3 on: 10 March 2008, 20:22 »
each door has two top half hinges and two lower half hinges, it's the top hinges that bugger up. If yours is a later model you'll see the star drives which need to be removed to get the hinges apart
Offline gtiscott
« Reply #4 on: 11 March 2008, 14:59 »
i take it i have to take the door right off to change these and also do i need to paint them?
Offline Pete Taylor
« Reply #5 on: 11 March 2008, 15:46 »
yep they will need painting and the door will have to come off. You can undo the door and support it on a block of wood on a jack though
Offline G60GTI16V
  • GTI Mk1, 2, 3, 4 now VRS Hell Yea!
« Reply #6 on: 11 March 2008, 19:27 »
that sounds like an annoying one  :angry: glad mine aint bad yet now saying it knowing my luck it'll happen
Offline gtiscott
« Reply #7 on: 11 March 2008, 20:01 »
i think i will just do both doors at the same time... i have noticed when i open the drivers door it feels as if it drops very slightly so i take it changing the hinge will fix this to
Offline tim145tim
  • 1997 GOLF GTi 16v ANNIVERSARY Mystic Blue Pearl
« Reply #8 on: 11 March 2008, 21:33 »
i get wind noise above 70mph from the front passenger side nearish the wing mirror
recent windscreen but still the same noise before as it is now...
any ideas
Offline kr1s77
« Reply #9 on: 12 March 2008, 04:30 »
i noticed the other day that my drivers door does this. drops ever so slightly.
ASV 1.9 TDI 110
