Author Topic: Heavy steering in wet  (Read 1918 times)
Offline sylhetstar
« on: 10 March 2008, 13:58 »
Hi I noticed today that my steering felt very heavy at 2 occassion, it became so hard that i ended mounting a massive curb. I stopped and checked steering left/right full locks and its fine. Then drove on and it started again, this has happend just today? I am sure i did not go through any puddles? any ideas guys?
2L Gti 8v 97
thanks
Offline Horney
Re: Heavy steering in wet
« Reply #1 on: 10 March 2008, 14:00 »
Check your power steering belt, probably needs tightening replacement.
Nick
Offline Pete Taylor
« Reply #2 on: 10 March 2008, 18:27 »
It feels like you have no steering, weird and scay aint it. It's because the power steering belt is warn and was slipping in the rain, usually does it round right hand bends. The belts are about £4 to replace so it's not worth tightening an old one
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 10 March 2008, 19:02 »
and if it really freaks you....vw did specify (on some models but not all it seems) a splash gaurd.. check breakers or ebay
Offline Simply Ed
« Reply #4 on: 10 March 2008, 19:35 »
This has been asked quite a few times before.
As its only in the wet, it means its a water related problem in relation to the belt. Water + Rubber = Slippy.  :wink:
but not in a weird way!
Thus we must conclude that the water is making the belt slip for the power steering pump. This has happened on a few cars I have driven of various different marques. Remedies include driving slower in the rain and fitting a splash guard if you are really that bothered by it.
If you had a slack belt, the problem would occur even in the dry.
Hope that helps!
Offline sylhetstar
« Reply #5 on: 12 March 2008, 13:09 »
does anyone know the part number or has a description of this splasher guard? My problem only happened in the rain and only twice on a 10mins stretch. It is scary stuff  :shocked: , it happened near a school first time and i ended mounting a kerb. It was on both left and right hand turns as well.
I would appreciate if anyone can help me locate the splash guard. My belts were changed only few thousand miles ago as well.
thanks all
Offline Mikester
  • Civic Type R
« Reply #6 on: 12 March 2008, 13:15 »
i might get one of these if someone can locate the part number, and it dont look g*y as it would be helpful, when i loose control in the wet, as its guna happen some day  :wink:
Offline tim145tim
  • 1997 GOLF GTi 16v ANNIVERSARY Mystic Blue Pearl
« Reply #7 on: 12 March 2008, 14:06 »
mines been screeching a little in the rain recently...
they sound cheap.. how hard are they to fit?
Offline Pete Taylor
« Reply #8 on: 12 March 2008, 14:13 »
I've got a splash guard in my garage brand new with VW part no sticker on it. I'll find it out and let you know
Offline sylhetstar
« Reply #9 on: 12 March 2008, 15:16 »
Topman Pete
