Author Topic: Electric Windows (doing its own thing!)  (Read 2266 times)
Offline pridders
  • Pearl Black 5 Door DSG GTI 05
« on: 10 March 2008, 11:59 »
Hey All,
I have had my drivers window open slightly recently for a bit of fresh air (and to listen to the Brrrb noises!) It has also been raining a bit recently so I have pressed the button to put it up and it has gone down about half way and stopped, not good when the rain is pouring in! When it goes down I cant override it so have to wait and then press it again to make it go up.
Anyone else had this?
Offline 08micsta
  • 1982 Mini 1275 Clubby
Re: Electric Windows (doing its own thing!)
« Reply #1 on: 10 March 2008, 12:09 »
Yip had this before:
Solution: Take to VW Dealer ans get them to reflash the CCM Computer/ Module.
Takes about 2 hours and MUST be free of charge. Its a safety issue and therefore no matter how old the car, must be fixed.
Mike
The Ultimate Club for Mini Fanatics
Join our group now!
No PAS. No ESP. No DSC. No TCS. No ABS. Just my right foot between me and oblivion. Oh - And a seatbelt.
Offline pridders
« Reply #2 on: 10 March 2008, 13:31 »
Nice one, Thanks. Its going in for its 30k service in 1k's time so I will get them to do this then. So will this also update the ECU with the latest version and make everything run a little better?
Offline stevieC
« Reply #3 on: 10 March 2008, 13:38 »
Pridders the last time my gti went in for warranty work it got the latest ecu upgrade and it felt smoother plus quicker. :smiley:
Gtd 3dr candy white,charleston shadows
Offline 08micsta
« Reply #4 on: 10 March 2008, 13:42 »
No.. Not all. The CCM computer also known as the Central Conveniance Module has nothing to do with the running of the car. Its simply makes sure that all the creature comforts and electronics work.
The ECU however is the engines computer. Most Gti's do get a reflash and update of that computer too which means that yes. The car will be so much smoother and you may find a slight power increase.
Hopefully that helps  :smiley:
Join our group now!
Offline 08micsta
« Reply #5 on: 10 March 2008, 13:45 »
By the way. After rereading your first post it might not be the CCM computer acting the goat. Usually when that computer is on the brink ALL windows would be effected and not just one. But its electronic so anything is possible.
If a reflash does not solve the problem they take the door panels off (and usually never put it on properly again) and check the wiring etc. Most common cause is a faulty window regulator which should be a quick fix.
Hope that helps
Mike
Join our group now!
Offline pridders
« Reply #6 on: 10 March 2008, 14:03 »
Hope that helps
Mike
Thank's Mike that more than helps, cheers  :smiley:
Offline pridders
« Reply #7 on: 10 March 2008, 14:05 »
Nice one mate i'll request that they do this, bring on the next 1k of glorious motoring!
