Author Topic: Oil Pressure Switch  (Read 892 times)
Offline operaghost
Oil Pressure Switch
« on: 09 March 2008, 23:20 »
Hi All!
Maybe bit of a daft question, but hoping someone might be able to help.
Oil pressure light and siren come on at random intervals when driving car; usually blipping throttle clears it again.  Have checked oil level and all seems OK.
Have been led to believe may be oil pressure switch.  However, local part place has twol isted for my car, 1.8 mk3, engine type AAM, with different pressure settings.
Can ayone advise which is the correct switch for the AAM engine?
Thanks in advance!  :smiley:
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Oil Pressure Switch
« Reply #1 on: 09 March 2008, 23:40 »
Worst case, knackerd bottom end, or worn out oil pump,  more likely...  your pressure switch or another similar fault on the electrical system.  :wink:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 10 March 2008, 12:51 »
the one fitted should have a tell tale coloured ring for identification....
kells
« Reply #3 on: 10 March 2008, 17:27 »
my local supplyer didnt have any with the same colour as my original one, their were 3 listed for my engine, all different colours to what mine had on it, my new one has blue ring (old was sh!tty brown) and its been spot on...
