Author Topic: Making ya car impractical  (Read 5355 times)
Offline TurboBeast
Re: Making ya car impractical
« Reply #10 on: 09 March 2008, 21:16 »
This is why I avoid lowering my cars at all costs.  The G2 Syncro I have is at the ride height it is so that it handles.  That means sucks bumps up and will suffer vicious compressions when pushing on without bottoming or topping out.  If you want to drive fast in the UK you need supple suspension, not a 'slammed' car.  Yes, it may handle 'like a go-kart', but that means they'll be bounced off line and you'll spend way too much time belting the bumpstops.
I've been told before by people that the rough ride is 'the price of being radical'.  If back-damage is radical, count me out.
My T4 Syncro actually runs a higher ride height than standard, as it's running on Bilstein dampers and Seikel springs.  Despite running high, because the dampers are quite stiff it handles very well.  Lowering and improving handling are not really linked, people just like to make out they are, but it's more aesthetics, as far as I can make out.
Both lowering and stiffening will improve the handling of a car it's all about centres of gravity.  Although what I do know is if you feel body roll no matter how good the car can handle your mind will tell you to back off.  So much in driving is to do with perception and how brave you are mentally along with skill.
I do agree with one thing it is useless buying a Ferrari now because with the speed bumps etc there is no way to use any pace whatsoever in a car with such a low suspension.
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
« Reply #11 on: 09 March 2008, 21:29 »
Not necessarily, ideal suspension set up is apparently having soft springs with huge ARB's. However this isnt really practical. Its also not necesarily a case of being as low as you can go. 40mm is the ideal drop for a mk2 golf for instance as it levels off the wishbones and driveshafts.
Offline lewis1641
  • stuck in the 90's
« Reply #12 on: 09 March 2008, 22:13 »
i think some people go really slowly over speed bumps to make it loo like their cars are really low.  the locals do this in their standard corsa's down cleethorpes sea front and it always makes me chuckle
Offline boneybradley
  • Back in a Mk3...
« Reply #13 on: 09 March 2008, 22:24 »
I had a similar problem today...my mate drives a random jap import and just to go for a drive he had to plan the route avoiding speedhumps.... and the best bit is due to roadworks theres no way from his house!! that fkd his sunday run out idea's!...
Offline antogoof
  • bbm mk2 g60
« Reply #14 on: 10 March 2008, 10:42 »
i had a mk2 8v a couple of years ago with a 60mm drop. i loved the look of the car but there are too many speed bumps around here and i ended up with a shaved front splitter which was a pain in the arse! sticking to 40mm next time.
mk2 bright blue met bits wanted in north west.
Offline cняis
« Reply #15 on: 10 March 2008, 11:03 »
i agree with 40mm if you want to lower your mk2, i have no issues with the daily and speedbumps.
i think i might keep the project as standard tho as the daily's suspension is a bit harsh on long journeys!
Offline Horney
« Reply #16 on: 10 March 2008, 11:06 »
I'm drop 60 and need to fettle my exhaust about once a month. I have to slow down for the hardcore speed bumps but normal ones are ok. Suspension is rock hard so girls require a sports bra. Other than that it's rockin!
Nick
Offline Diamond Hell
  • Opinions я Us
« Reply #17 on: 10 March 2008, 11:14 »
You thought about running stretched tyres with that set up, Nick?
Offline Andy!
  • VR6
« Reply #18 on: 10 March 2008, 11:26 »
Kidneys are overrated anyway!
« Last Edit: 10 March 2008, 11:34 by Taxiboy »
Offline Horney
« Reply #19 on: 10 March 2008, 11:28 »
Well I did, but I realised if I went down that route I'd have to buy some skinny jeans and get an emover hair cut and a bonet bra.
Nick
