Author Topic: rip-off dealers! knock sensor  (Read 1338 times)
Offline cняis
« on: 07 March 2008, 13:20 »
Hi all
i'm looking for a knock sensor and the dealer has quoted £51!! bloody cheek!
ive posted in the wanted section TWICE but nobody seems to have one?
someone help me out, the pinking is getting annoying!
 :cry:
also will a G40 knock sensor work?
« Last Edit: 07 March 2008, 13:31 by Crevice »
Offline cняis
Re: rip-off dealers! knock sensor
« Reply #1 on: 07 March 2008, 19:42 »
bump
does anyone know if repairing the dodgy wiring from the sensor will help? i was thinking insulation tape and heat shrink...?
Offline Diamond Hell
  • Opinions я Us
« Reply #2 on: 07 March 2008, 20:36 »
It's not like it's a temperature sensor - this is a rather more sensitive piece of kit, hence more expensive.
Where in Somerset are you?
If you're not too far from Bristol give Vee W Services a call tomorrow morning on 0117 941 8641 and see what price they can get the knock sensor for.  GSF don't seem to list it, but that's no real surprise as it's not something that goes very regularly, as far as I can make out.
Offline dadrathers
« Reply #3 on: 07 March 2008, 22:29 »
I know it is expensive but I ended up not being able to source one at anything much less - so paid my local dealer the full £51. Go for it!
Offline filthy
« Reply #4 on: 07 March 2008, 22:52 »
Can't you just alter the timing a little?  that might work.... :smiley:
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
Offline adihodgson
  • DUB......Deuchland's ultimate benchmark
« Reply #5 on: 08 March 2008, 09:16 »
Hi all
 :cry:
On a previous 8v Gti I owned, I has the same pinking........tried all sorts to cure it inc Knock sensor & ECU change. It was only when I had the head gasket changed  that it cured the prob. You might need the head de-corked?
Offline cняis
« Reply #6 on: 08 March 2008, 10:28 »
Hi all
 :cry:
hmm well this has been recommended but the car isnt worth it (in labour charges).
  • Opinions я Us
« Reply #7 on: 08 March 2008, 11:58 »
I'd avoid getting your head de-corked - that would just remove the remains of the cork rocker gasket  :wink:.  A de-coke is what you're after.
If you can check the timing then a good thrash will de-coke it, but to be fair I think it's more likely that the knock sensor is the problem.  One from a 2E Passat will do you.  There's a couple up in Yate Breakers, if you're not too far away from them.
If you want an example of dealer-expensive, how about £40 for a breather pipe - it's just a single, simple pipe that goes from the block breather, to the rocker.
Now that smarted this morning!
