Author Topic: Sat Nav Fitting instructions  (Read 3119 times)
Offline DaveN
Re: Sat Nav Fitting instructions
« Reply #10 on: 06 March 2008, 16:40 »
Yeh, I used 90% of that guide for the install, I put my gps antenna up beside the rear view mirror as I was having trouble with it in the dash. When replacing it all back put some felt strips in to stop any rattles otherwise it will squeak.
Dave N
I think the worst time to have a heart attack is during a game of charades. Especially if your teammates are bad guessers.
Offline The Wheel Man
« Reply #11 on: 07 March 2008, 13:13 »
Sorted.  Took about an hour in the end (is was pitch black).  Getting the last plug in the top pallet was a right bugger.
In the end i have put the antenna as per the instructions on the top of the dash.  i will see how much that gets on my nerves before moving it to a different location.  For my first ever attempt at fitting something with wires attached, i think that is was pretty easy.
Thanks for all the feedback and the great link!!
Offline duzza
« Reply #12 on: 07 March 2008, 13:51 »
+1 on putting the sensor under the dash, I fitted my ebay sourced OEM unit at the weekend and put it in a small space to the top left of the unit, I used a sticky pad to prevent it moving).
I found the whole thing easier to install than expected, but do make sure you have a good trim removal tool. Also put a cloth on top of the dash to prevent scratches when you move the top vent housing.
I put my antenna there too, seemed OK (not always perfect) until a few weeks back when it just wouldnt find a signal at all. Had to bring it out and stick on to the air diffuser (magentically)
GTI Edition 30, Metalic grey, MFD2, Highline, R32 Wheels
