Author Topic: Resetting/Adjusting Speed Warning  (Read 3401 times)
Offline maxamus
« on: 05 March 2008, 23:31 »
Anyone know how i can reset / adjust it on the computer?
Its on 70mph and i always go over it when on motorway and it starts flashing......
Offline dubaiphil
Re: Resetting/Adjusting Speed Warning
« Reply #1 on: 06 March 2008, 05:16 »
Hehe!  Count yourself lucky.  In Dubai every car has a speed warning - you go over 120km/h and the car beeps at you until you drop under again!  Good excuse to put the stereo up and gun it though, so you can't hear!
Tornado Red 5 door, DSG, 18", Xenon, Cruise, Leather, Climatronic, Sunroof, RCD500, iPod prep, Mirror Package, Parking Sensors
Offline pany
« Reply #2 on: 06 March 2008, 08:33 »
iirc you bring up the speed warning, then hold the rset switch on the stalk for 2 seconds. It should then flash, and the up / down switches alter the speed. Go down low enough and it cancels.
Offline maxamus
« Reply #3 on: 06 March 2008, 10:22 »
i tried that but it didnt work.
Do i need ignition on or off or handbrake on or off??????
Offline maxamus
« Reply #4 on: 07 March 2008, 08:28 »
anyone?
Offline joesgti
« Reply #5 on: 07 March 2008, 09:20 »
mine dosnt beep, thats all i know and ive been at gps 156mph  :smug:
GTI MK5
Not the only GTI...........but the best! ; )
Offline vw_sales
« Reply #6 on: 07 March 2008, 09:33 »
What do u want to do zero it or set at a higher speed.
Offline maxamus
« Reply #7 on: 07 March 2008, 12:45 »
higher speed
Offline topher
  • Administrator
  • fully functioning
« Reply #8 on: 07 March 2008, 12:48 »
I was messing around with this yesterday. Stationary with the ignition on, cycled through the display until i got to the speed warning (set at 75). Held the reset button on the underside of the stalk for a couple of seconds.. nothing happened. Let go and tried it again, then did some doublejointed ninja move to click the up/down button at the same time, and when i let go this time.. the speed had been reset. Then just clicked it up to 85mph and pressed 'ok' again. I really doubt that's the right way to do it, it was probably lotto but it worked for me.
Offline vw_sales
« Reply #9 on: 07 March 2008, 13:00 »
Drive the car at the speed you want and press the little button under the stalk, whilst the MFD is set to speed warning twice.
Once to zero it
Once to set it to the speed you want.
When you press it the second time, you will set it to what ever speed you are doing.
