Author Topic: Correct tyre PSI's??  (Read 2402 times)
Offline tim145tim
  • 1997 GOLF GTi 16v ANNIVERSARY Mystic Blue Pearl
« on: 05 March 2008, 20:09 »
Hi there I have standard 16" anniversary alloys on my car...
they each have 205/50 R16's on there at the moment ...
Ive heard some people with the same wheels say they have 215/45 r16, and others 205/40 r16 etc...
so how do I know what psi is the right amount for my tyres?
anyone know?
Offline saul79
Re: Correct tyre PSI's??
« Reply #1 on: 05 March 2008, 20:12 »
2.1 bar on the front and 2.0bar on the back-i have mine on this .
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline tim145tim
« Reply #2 on: 05 March 2008, 20:28 »
same size tyres?
Offline saul79
« Reply #3 on: 05 March 2008, 22:38 »
205/40's
Offline LazyLunatic
  • MK3 20VT Project
« Reply #4 on: 05 March 2008, 23:49 »
If you can get hold of a Haynes manual check in there. I think mine says something like 22-26psi. Will check 2moro and post it up. I have a 1.4 though, so may vary slightly. If you dont have a manual/haynes manual or a sticker on the car somewhere that tells you tyre pressure, then go to Halfords and just check the pressure in a Haynes manual in store. That way you don't have to buy it! :grin:
LL ;)
Offline Stu G
« Reply #5 on: 06 March 2008, 08:02 »
ive been playing with my tyre pressures recently. got 205 40 17s. found 32 was a bit too hard. so dropped them down to 30 and was better. go with what ever is comfier but generally 30 32 psi
Offline Si GTI
« Reply #6 on: 07 March 2008, 14:54 »
Hi
Haynes manual says 29 PSI front 26 rear for those tyres. Or a couple of PSI less if your only ever in the car on your own.
Si
Offline tim145tim
« Reply #7 on: 07 March 2008, 14:59 »
for waht car/ size?
Offline richking
« Reply #8 on: 07 March 2008, 18:44 »
ive got an anniversary and inside the fuel flap it says the standard tyre size is 215/40/16 the fronts are listed as 38 and rears 35
Offline tim145tim
« Reply #9 on: 08 March 2008, 00:36 »
cheers mate what an idiot i am i havent even looked inside the filler flap yet
