Author Topic: Revo and DV's etc..  (Read 4587 times)
Offline vRStu
Re: Revo and DV's etc..
« Reply #20 on: 21 March 2008, 21:13 »
Just seen the massive picture in the sig, ED30  :embarassed:
Doh.
Stu
Offline 182_blue
« Reply #21 on: 21 March 2008, 21:24 »
how easy it it to change the DV
It is easier on the ED30 as it is remotely positioned at the front of the engine - almost at the side of the air intake. You will have to take off the engine cover though.
cheers, and what about the fuel pump ?
Offline vRStu
« Reply #22 on: 21 March 2008, 21:36 »
There are install instructions here for the AutoTech pump -
http://www.autotech.com/instructions/i127100k.pdf
They are a little over comprehansive in some area's and a little lacking in others.
It is important to make sure the engine is aligned with CYL1 at TDC before starting.  It isn't necessary to fully strip down the pump as shown in the guide, simply swapping out the piston is adequate.
Time wise I would allow a good hour for the first time.
Stu
