Author Topic: heater blower repairs  (Read 878 times)
Offline TheSteve
« on: 04 March 2008, 16:30 »
Thanks for all the hints on this topic................helped enormously in fixing my son's blower which was only working on setting 3! We eventually managed to fix it for 65p and a bit of time and patience. It is a LHD model and replacing the resistor panel was going to be nearly £50! ( surely there is no difference in the electronics?). Solution was to take the panel to local electronic retailers who sold me the correct rating in-line fuse. We cut away the old one on the back of the panel, soldered in the new one, lubricated the bearings and were back in business. Still working up to press (1 hour after fixing!)   :smug:
Offline mattkh
Re: heater blower repairs
« Reply #1 on: 05 March 2008, 11:32 »
Hi
What did you use to lube the bearing ?
Offline cняis
« Reply #2 on: 05 March 2008, 11:39 »
you can buy bearing grease from most motor factors
