Author Topic: Alternator cable on 16V GTI  (Read 1107 times)
Offline nelds
  • Now Golfless but owning an Audi still counts
« on: 02 March 2008, 19:03 »
i was checking the water and oil on my 16V today and noticed a wire that doesn't seem to go anywhere. It comes off the side of the alternator, it's a thin wire than sort of pigtails out of the fatter cable. It has a connector on it that has a plug in it which looks like it snapped off of something........any ideas.....??
Offline saul79
Re: Alternator cable on 16V GTI
« Reply #1 on: 02 March 2008, 19:24 »
some have a spade connector on the back off the altermator check the back off it to see if theres anything missing
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline nelds
« Reply #2 on: 02 March 2008, 19:52 »
added some pictures to see if it helps......i've circled the small wire in red, and the plug with the snapped plastic attached is circled yellow
Offline saul79
« Reply #3 on: 02 March 2008, 19:56 »
should be connected to the alternator -has a spring clip holding it on too
Offline nelds
« Reply #4 on: 02 March 2008, 19:59 »
the spring clip is still on, i pinched it open and pulled plastic away but it obviously connects to nothing. what's it's function..??
Offline vdub virgin
  • If it aint broke....dont fix it!!
« Reply #5 on: 02 March 2008, 20:02 »
it plugs into the front of your alternator dude,lookin directly at the alternator frm front of car,that wire cums up frm the rite hand side of the alternator n plugs into the front of it  :smiley:
Offline nelds
« Reply #6 on: 02 March 2008, 20:05 »
cheers fella.......does it matter that it's broken then..??....i think this motor had a front end smack at some point cos i keep finding little bits broken   :rolleyes:
Offline nelds
« Reply #7 on: 02 March 2008, 20:32 »
can i just glue it back in place..?
Offline vdub virgin
« Reply #8 on: 02 March 2008, 20:40 »
yeah,mines rite behind the rad so if your rads bin smashed back..................... :rolleyes:
dnt no,it could be a supressor,u no to stop interference with your radio etc,id just tuck it outta the way sumwhere!
