Author Topic: Mk3 16v GTi Headlight Problem  (Read 1567 times)
Offline jgslone
« on: 02 March 2008, 17:47 »
Hi all,
About 2 months ago i was driving down the motorway at 70mph and my front drivers side tyre blew, leaving me travelling on the rim. It caused quite a bit of damage, but i've now had it all fixed. However, i noticed about a month ago that the headlights were a lot worse than they had been. I took a look at the drivers side and found that it was all smashed up inside. So, i've fitted a new one and got it all wired up. But it's still not great! When i flick the full beam on it turns the dipped beam bulb off! This only happens on the drivers side, the passenger side is fine. The drivers side lamp just seems to drain all the power from the dipped beam connection when the full beam is turned on.
Sorry for the long post, but if anyone's got any ideas at all then i'd love to hear from you.
James
Offline saul79
Re: Mk3 16v GTi Headlight Problem
« Reply #1 on: 02 March 2008, 19:42 »
check condition off plugs on the head light
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline mark j b
« Reply #2 on: 02 March 2008, 23:34 »
are the dipped bulb not ment to go off when full beam goes on?
Offline Mikester
  • Civic Type R
« Reply #3 on: 02 March 2008, 23:35 »
nah, they are seperate bulbs and units, maybe the sidelgihts go off, as the sidelgiths and full beam are in the same part.
Offline mark j b
« Reply #4 on: 02 March 2008, 23:51 »
so should dipped stay on?mine go off :huh: its a mk3 1.4
Offline Mikester
  • Civic Type R
« Reply #5 on: 03 March 2008, 00:05 »
ahh, they dont have the twin lights like the gti's doo, so they would go off.
Offline boneybradley
  • Back in a Mk3...
« Reply #6 on: 03 March 2008, 08:49 »
as mike has said the standard lights use a single bulb for dip/main and the gti (twin lights) use seperates... yours will go off when switching from dip to main
Offline jgslone
« Reply #7 on: 03 March 2008, 13:41 »
Yep, checked the fittings on the headlight unit and they seem fine. I wondered if it might be a loose connection in the main fuse box or maybe a dodgy earth?
Offline Mikester
  • Civic Type R
« Reply #8 on: 04 March 2008, 10:00 »
Lol, read what me and boney posted!!!!! The answer is there mate.
Offline 95gtipete
« Reply #9 on: 04 March 2008, 14:26 »
wires could be the wrong way round
