Author Topic: rear engine mount  (Read 786 times)
Offline beni-iow
rear engine mount
« on: 02 March 2008, 16:51 »
hi there ive just replaced my front engine mount and noticed that the rear one (drivers side)is going but cant work out how it would come out has anyone replaced one of these before,if so how do you go about doing it?
thanks ben
Offline saul79
Re: rear engine mount
« Reply #1 on: 02 March 2008, 18:51 »
remove the rear engine mount bracket alloy part bolted to engine
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline beni-iow
« Reply #2 on: 02 March 2008, 19:46 »
i didnt see that bit well i mite of but it looks quite difficult as the driveshaft is in the way
Offline saul79
« Reply #3 on: 02 March 2008, 19:55 »
mount is held on with 4 13mm bolts and the bush is held on with 2 13mm bolts -you can remove it without removing the driveshaft
Offline beni-iow
« Reply #4 on: 03 March 2008, 10:42 »
ok cheers mate
