Author Topic: Lost a bit of power  (Read 734 times)
Offline Ciderdan
Lost a bit of power
« on: 02 March 2008, 13:14 »
Changed my cambelt yesterday, she runs fine, but seems to have lost a bit of power, also 'stutters' a tiny bit.  Just noticed though a rather large hole in my back box!  (Thought she was sounding a bit racy!!).  Might the knackared back box cause the loss of power?
Keep the Faith
VeeDubGTI16v
Re: Lost a bit of power
« Reply #1 on: 02 March 2008, 13:21 »
you might be a tooth out on the cam belt, happened to me once on the old 16v and it lost about 30bhp!
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #2 on: 02 March 2008, 14:32 »
I think you need to look at your settings again. As said just now, you could be a tooth out either on your cam pulley or distributor drive. Blowing exhausts will not help either.
Offline Ciderdan
« Reply #3 on: 03 March 2008, 19:20 »
Thanks for the replys boys.  Would the engine run if she were a tooth out?.  I thought the 1800 was an 'interference' engine.  she sounds fine and did go up to about 90, but the bit of 'spark' just wasnt there.  Would the back box make a bit of difference?
Keep the Faith
VeeDubGTI16v
« Reply #4 on: 03 March 2008, 19:28 »
it would still run yeah, just feels 'strangled'! if i were you id turn the engine until you think its at tdc, then take the spark plug out of no1 and put a stick or something down there, then turn the engine on the crank bolt and check it actually is at tdc.
