Author Topic: how to remove mk3 front grill badge  (Read 4961 times)
Offline golfmk31993
« on: 01 March 2008, 22:32 »
hoe do i remove the vw badge from my front grill???
the chrome has worn off so it is just plastic so i wanna take it off and paint it black  :cool:
thanks
Offline boneybradley
  • Back in a Mk3...
Re: how to remove mk3 front grill badge
« Reply #1 on: 01 March 2008, 22:36 »
theres 3 clips that need prying with a small flat screwdriver.... unclip and pop out
Offline Guy
« Reply #2 on: 01 March 2008, 22:37 »
easy -
i found the easiest way is to take the grill off
there are four clips just on the top edge between the lights
there are another two clips just beneath the lights - use a screwdriver to prise it out
when you are handling the grill take it easy and do it gently - should come off no problem
then you'll see that you can just lever the three clips on the back of the badge and it'll pop out!
Offline LazyLunatic
  • MK3 20VT Project
« Reply #3 on: 01 March 2008, 22:38 »
Im doing that to mine tomorrow!
Mine just clips right out. There is 3 places where it clips on; top, bottom left and bottom right (120 degree angle between each clip, if you know what i mean).
Also doing the rear badge. Oh and don't forget clear laquer!
LL ;)
Offline Guy
« Reply #4 on: 01 March 2008, 22:38 »
sorry boney - i have gone against your advice.. I have found it is easier to pop the grill off to get any leverage...
  • Back in a Mk3...
« Reply #5 on: 01 March 2008, 22:44 »
My badge has being changed that many times..it nearly falls out..
Offline LazyLunatic
  • MK3 20VT Project
« Reply #6 on: 01 March 2008, 22:46 »
yeah same here, i can sort of slide it out a bit and then clip it out! :laugh:
LL
Offline Guy
« Reply #7 on: 01 March 2008, 22:49 »
oic - that is where the difference is
mine was so tatty that I got a brand new one from the stealers last summer... come to think of it the old one I managed to lever out easily but this one is set in there like stone
Offline remapped
  • If you are going through Hell, keep going
« Reply #8 on: 02 March 2008, 12:05 »
mine pulls of buy hand  :sad:  :shocked:
mmm maybe the car wants a black badge ????
OEM(ish) G3GTi 8v5dr
  • Back in a Mk3...
« Reply #9 on: 02 March 2008, 12:25 »
I have 3 different badges...silver,black and body coloured..and each one simply clips/falls out!
