Author Topic: MAF sensor (groan)  (Read 1226 times)
Offline DessertsRUsLtd
MAF sensor (groan)
« on: 01 March 2008, 21:41 »
Hi gang,
You've probably talked about this until the cows came home but...
My 2001 Gt-TDi has been problematic from the day I bought it from the dealership. In short, it came down to me to solve the problem which appears to be a faulty MAF sensor. It's been replaced but the one that they fitted appears to be incomplete. If you know the part then you'll see on the outer casing a small wire, almost paperclip-shaped, attached to two small brass-like clips. Well, mine's doesn't have the piece of wire. I've got a pic of the part which is the same as mine and it was then that I noticed the wire was missing from mine.
Bottom line; heavy smoke under acceleration, poor 'dropping in and out of power' throughout the rev range and outrageous fuel economy. I'm currently running the car with the thing disconnected and, although it's not a snappy, it's just better all round with no ugly shuddering etc.
So, in conclusion - do all the models with this type of MAF sensor (Bosch type - PBG PF-30) have this outer wire or just the petrol engines. you can see a pic of the sensor on the link below and you'll clearly see the wire on the outside of the casing that's missing on mine.
Help!!
Offline Kenny_1.6
  • it will be a GTi... some day... lol
Re: MAF sensor (groan)
« Reply #2 on: 02 March 2008, 15:16 »
this is why i love SPI's... no air flow meter's  :laugh:
Men have two emotions: Hungry and Horny. If you see one without an erection, make him a sandwich. :D
Offline gangeox
« Reply #3 on: 04 March 2008, 12:52 »
I'm no expert  :laugh: but i reckon that wire will be very important it looks like an odd type of resistor  :shocked:.
Have you checked the air filter by the way?? diesels need lots of clean air to run less smokey.
MK 4 2.0 GTI Nothing added and nothing taken away!!
