Author Topic: FAO Mk3 Golf GTI 16v drivers  (Read 1735 times)
Offline DMackie
« on: 29 February 2008, 17:59 »
I just wanted to ask what type of filter you have on your cars, i like the BMC one but they only do one for the gti 8v and VR6 is this true?
So what do you guys have in the way of induction kit or perfomance panel filter?
Cheers DMackie
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
Re: FAO Mk3 Golf GTI 16v drivers
« Reply #1 on: 29 February 2008, 18:23 »
http://www.golfgtiforum.co.uk/index.php?topic=75868.0
Had a Raidhp induction kit on my valver and was well happy with that.
Offline eightyeightmph
« Reply #2 on: 29 February 2008, 19:10 »
What! BMC CDA fit's a 16V.... got one on mine, you need the larger one for 1600cc + with the 85mm intakes....
Et voila!
2016 GOLF GTD
Offline vdub virgin
  • If it aint broke....dont fix it!!
« Reply #3 on: 29 February 2008, 19:49 »
gt a k&n on mine n sounds well,jst need to get blowy zorst sorted cos its spoilin sound at low revs :sad:
Offline Pete Taylor
« Reply #4 on: 29 February 2008, 20:48 »
Et voila!
Dude, should you not of blocked off that hose at the top of the throttle body?? Seems you'll have a big air leak of unmetered air with that as it is
« Reply #5 on: 01 March 2008, 22:40 »
Which one where now??
2016 GOLF GTD
Offline Pete Taylor
« Reply #6 on: 02 March 2008, 14:54 »
The hose i've lined in red, if that isn't connected anywhere at the other end then it should be removed and blocked off with a rubber bung at the throttle body where i've put a green arrow
« Reply #7 on: 02 March 2008, 17:33 »
Ohhh right, yea think it's plugged in somewhere!
2016 GOLF GTD
Offline Greg
« Reply #8 on: 04 March 2008, 13:27 »
I use a pipercross filter. GSF did them for a good price, about half that of a K&N. Made little or no difference though.
Do the CDA intakes make a noticeable difference in power?
'99 Mk4 1.8T - FMC007p - R-Tech Stage 1 | '97 Mk3 16v | '91 Mk2 16v | '83 Mk1 L
http://blackgolfgti.blogspot.com
« Reply #9 on: 04 March 2008, 13:36 »
Yes, did a little write up not long ago but definately more torque & feels loads more pokey!
2016 GOLF GTD
