Author Topic: Horns, Need reply asap  (Read 2627 times)
Offline Mikester
  • Civic Type R
« on: 29 February 2008, 13:20 »
Fitting vents for the front, and the horn is in the way, i fighted for 10mins just now to get it off and cut up my arm to get it out. Now when i sound the horn is a more of a sweaky horn, as i believe there is two horns.
My question is, will this pas the mot a.ok as there still is a horn, just not as powerful as before?
Mikeee
Offline vdub virgin
  • If it aint broke....dont fix it!!
Re: Horns, Need reply asap
« Reply #1 on: 29 February 2008, 13:32 »
i think so mate,cant see why not
Offline Mikester
  • Civic Type R
« Reply #2 on: 29 February 2008, 13:36 »
Yeah, i hope so, because im going to give it a go! lol.
I suppose i could rewire it to another part of the bay, but that is a lot of ache for extra horn power :/
Offline vdub virgin
« Reply #3 on: 29 February 2008, 13:47 »
yeah,but could b embarrassin using ur horn in public as it is!lol!
growling GTI goin by and then it gives out a little "toot,toot!"  :laugh: :laugh:
Offline RiCHiE360
« Reply #4 on: 29 February 2008, 13:48 »
Just buy a new aftermarket horn on the cheap and fit that mikester then you'll be nice and loud  :smiley:
Roofless VR6 FTW
Offline bored_Welsh_lad
« Reply #5 on: 29 February 2008, 14:20 »
you shouldnt have to take the horn off lol...
you can just rotate it and it should be fine mate.
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
ShoCk
« Reply #6 on: 29 February 2008, 14:33 »
I bent my horn back on to the chassis. Still sounds fine.
« Reply #7 on: 29 February 2008, 14:35 »
Try wiggling the top chrome plate thing, maybe something is touching that and changing the noise..
or buy some air horns!!!
Bumper Vents :D
Offline Mikester
  • Civic Type R
« Reply #8 on: 29 February 2008, 15:04 »
I have cuts up my arm where i was fighting with it, so i wiggled it, and it came off in my hand,!!!so yeah! No more horn. Im totaly fed up of trying to fit those vents today, so i reckon i willjust extend the wires and fit it elsewhere....
Offline vdub virgin
« Reply #9 on: 29 February 2008, 16:35 »
there is two horns mikester,just looked at mine.
the second 1 is located down the side of the bumper(inside obviously) about 6" up frm the bottom,on the same corner as the other horn.u cn see it from above if you dont have an airbox,look down the hole behind the headlight.
1 must b hi note and 1 low note,b why yours sounds odd now!lol!
