Author Topic: I need to untint my rear lights.  (Read 1785 times)
Offline Khare
  • The bear that khares
« on: 28 February 2008, 22:29 »
At the moment my car is MOT failiure material because of the rear lights. The indicator light and reverse light are red, and i heard this is MOT failiure. I heard nail varnish can remove the tint from the corresponding light area to the reverse light and indicator lights. is this true? if not, what else is there to do?
Offline [han]
  • Graphic Designer for Haribo
Re: I need to untint my rear lights.
« Reply #1 on: 28 February 2008, 22:34 »
reverse lights are not essential for the mot.. so maybe just remove the bulbs?
Green  bulbs will sort the problem of the light flashing red on the indicators. Green bulbs still flash orange through a red tint.
Good luck.
Offline Khare
« Reply #2 on: 28 February 2008, 23:10 »
yh sounds good. i'l try that.
Offline [han]
« Reply #3 on: 29 February 2008, 00:03 »
my reverse lights don't work at all... so i know you dont need them.
but green bulbs def your answer to red tints.
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #4 on: 29 February 2008, 13:06 »
yo i got a pair of standard lights you can borrow for the mot if you want buddy? when is it?
Offline Khare
« Reply #5 on: 29 February 2008, 16:50 »
oh cheers russ. I'l try the green bulbs first anyway as i want to keep orange indicators though. Its due on the 6th of june, so still awhile to go. i also heard that the front water jets have to work for the MOT to pass. Is this true??
Offline [han]
« Reply #6 on: 29 February 2008, 17:05 »
changing stuff for an mot is not the answer. you should flash orange by law, and it could be construed as a dodgy brake light causing someone to slam on (idiots i know) but coul cause a problem. they need to be orange.
Offline Khare
« Reply #7 on: 29 February 2008, 17:24 »
yh thats what im saying. Thats why i want mine to be orange for the whole time not just MOT. but then again, no 1 has crashed behind me yet so...:D
Offline Philpy
« Reply #8 on: 29 February 2008, 20:28 »
Acetone that you can buy from your local chemist will take it off easy. Thats what ive used for removing light tint in the past!
Offline [han]
« Reply #9 on: 01 March 2008, 10:39 »
but why remove the tint when the problem can be solved  :rolleyes:
