Author Topic: Brakes Problem, help needed urgently!  (Read 1292 times)
Offline SimonGTI8v
« on: 28 February 2008, 17:57 »
Hi all, I own a Mk2 Golf GTi 8v and need advice with the brakes.
In a nutshell the problem is that a rear caliper started leaking, the pedal hit the floor and the brakes were almost non-existant. The caliper has been changed with a new one and the system bled but the pedal still goes to the floor.
Does anyone have any ideas on this???
Cheers Si
Offline JimR
Re: Brakes Problem, help needed urgently!
« Reply #1 on: 28 February 2008, 18:09 »
Either haven't been bled properly or the the new caliper hasn't been connected to the hose properly, is the fluid level topped up at all times during the blleding? have a look round at all the calipers for signs of leaking and then bleed all 4 again.
Mk2 GTi.
Offline SimonGTI8v
« Reply #2 on: 28 February 2008, 18:27 »
Cheers mate, the caliper is connected properly and the fluid was kept topped up. There's no leaking that I can see and all the rubber brake pipes look fine (no bulging). Bled the brakes in the order the Haynes manual gives. They've been bled a few times now but still the same result.
Offline BIG D
« Reply #3 on: 28 February 2008, 21:49 »
I had the same problem with mine turn the caliper upside down and use a pressure bleeder
