Author Topic: Top mounts  (Read 2547 times)
Offline Scott
Top mounts
« on: 05 April 2004, 15:30 »
I changed my front top mounts a year ago (almost to the day!) and when filling the screenwash the other day I noticed there was about half an inch of free play between the top cup and the shock tower, I had noticed the ride being a bit more clunky than normal recently.
Surely top mounts should last more than a year??? or is there supposed to be some slack between cup and body (I would have thought not though). Help!
Mk4 PD150, Jazz Blue, nice! Puts my old Mk3 Gti to shame
golfvr6
Re:Top mounts
« Reply #1 on: 06 April 2004, 00:06 »
There is supposed to be a small gap between the cup and body, but it should be minimal.
Where did you get the mounts from? GSF?
Can you stick your finger between the cup and the body?
Offline Scott
Re:Top mounts
« Reply #2 on: 06 April 2004, 08:57 »
Mounts came from vw specialist in Cambridge, but they are the Febi ones. I can just about get my index finger between cup and body. Is that bad?
golfvr6
Re:Top mounts
« Reply #3 on: 06 April 2004, 10:28 »
Can you post a pic?
It doesn't sound too bad, but if they get any worse then you should change them.
GSF supply 'febi' mounts as well, some have proved not to be 'o.e.' quality.
turbo
Re:Top mounts
« Reply #4 on: 08 April 2004, 08:46 »
tim styles said ''the rule of finger is if you can get it between the top bit and the tower they need replacing''.. and he said ''always use genuine parts'' for that!
Offline Scott
Re:Top mounts
« Reply #5 on: 08 April 2004, 09:25 »
Cheers for that, looks like I have got my easter weekend sorted out! Will use VAG bits this time, see if they last more than a year!
Offline paladin
  • Call me old and I'll smack the sh!t out of you.
Re:Top mounts
« Reply #6 on: 11 April 2004, 20:40 »
What year is your Mk3? Are the struts original?
You might be able to switch for a VR6 set(bearings and bushings), they're much stronger,  worth looking into.
'94 Mk III 2.0
Bosal cat-back:K&N w/mod.airbox:GIAC
Alpine 9815
JBL BassPro
CDT Audio HD-52 in reinforced q-form kicks
MB Quart 218.21 (mid's) in rear
QuietCar (being applied)
