Author Topic: New suspension....still problems  (Read 1335 times)
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
« on: 28 February 2008, 00:31 »
Well after having my new suspension sorted thaught all problems associated with it were over.....but not quite yet it seems :cry:
When turning left (doesn't happen when turning right) there seems to be a bang and sometimes a groan, sounds like the spring is banging or moving in its seat, thirstly is this possible..? can the spring move or turn if say a nut or bolt isn't tight enough..? secondly could it be anything else...? car drives fine otherwise and there is no rubbing or anything like that.
This problem only started since having this Jamex kit put on, nothing like this with the previous suspension.
Offline filthy
Re: New suspension....still problems
« Reply #1 on: 28 February 2008, 17:49 »
Does the bang come from the front or rear? if its the front, it could possibly be your strut top mount bearing, or, if its the rear, you may have a knackered rear axle bush...
Its only a possibility mind.... :smiley:
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
Offline DazVR6
« Reply #2 on: 28 February 2008, 19:03 »
Noise comes from the front, it only happens when i turn left, but its from the drivers side as when turning left the weight shifts towards the right side...what could the creaking/groan from the steering be..?
Offline saul79
« Reply #3 on: 28 February 2008, 19:12 »
spring slipping on top mount cup ,mine did the same -get the coilovers  :wink:
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline DazVR6
« Reply #4 on: 28 February 2008, 19:14 »
Apart from getting the coilovers :rolleyes: anyway to stop the spring slipping..?
Offline saul79
« Reply #5 on: 28 February 2008, 20:25 »
how big is the top coil and does it fit in the cup. i welded 3 tabs on the cup and folded them around to hold the spring in place -worked well -then wanted it lower so got the coillies
Offline DazVR6
« Reply #6 on: 28 February 2008, 23:20 »
So nothing else could cause the spring to move when it is under load..? it only does it on the d/s/f.
Offline saul79
« Reply #7 on: 29 February 2008, 19:22 »
haha so did mine ,dont know why it was that side -maybe due to the extra weight on one side i dont know lol
Offline DazVR6
« Reply #8 on: 01 March 2008, 00:33 »
Wish i had just braught the collies...but alas its too late and i can't afford to spend any more money so this has gotta be sorted on way or the other. Think i'll just try and find someone who specialises in aftermarket suspension and get em to sort it :angry:
