Author Topic: speedo with 18's  (Read 2113 times)
Offline l4v15
  • GTi T 20v
speedo with 18's
« on: 27 February 2008, 23:11 »
hi. how far out will it put your speedo if you have 18's on the gti t? just wanted to know how far out mine will be. Also, when you lower the mk4 does it put the tracking, wheel alinement, camber etc out by much?
L4V15
Offline richw911
Re: speedo with 18's
« Reply #1 on: 27 February 2008, 23:34 »
You will have lower profile tyres on the 18's prob (225/40/18) so the amout you have gained on the rim you will lose on the prifile of the tyre.
The radius will be the same - So it will not put the speedo out  :wink:
As for camber etc that will depend on how low you go TBH. Always a good idea to get it all checked after lowering tho :afro:
Offline Chris 'N' Jen
  • MK4 2.0 GTi 8v in black (the best colour)
« Reply #2 on: 28 February 2008, 08:43 »
18's with 225/40/18 tyres shows you go slower by about 1 mph i think.
heres a handy little converter
http://www.dakota-truck.net/TIRECALC/tirecalc.html
type your standard tyre in A and you intended tyre in B and say submit, then click on full analysis.
 :smiley:
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 28 February 2008, 09:11 »
tbh the inaccuracy of your speedo probably gives more deviation than the very slight change in rolling radius. Above 30mph mine was constantly 4 - 5 mph out according to gps.
Offline l4v15
  • GTi T 20v
« Reply #4 on: 28 February 2008, 20:43 »
yea good stuff. thanks.
L4V15
