Author Topic: LL's Mk3 1.8t Cab  (Read 921310 times)
Offline dom
  • Back in a Mk4
Re: LL's Mk3 1.8t Cab
« Reply #3010 on: 25 January 2014, 12:11 »
Yeah, water traps are a must, have you got a tank drain as well?
You running 2 tanks and 2 compressors? What cc compressors are they?
Offline LazyLunatic
  • MK3 20VT Project
« Reply #3011 on: 25 January 2014, 19:28 »
Twin 450C (450cc??) They flow 1.66CFM each. And two tanks :)
« Last Edit: 25 January 2014, 19:36 by LazyLunatic »
Offline dom
  • Back in a Mk4
« Reply #3012 on: 26 January 2014, 14:58 »
:afro:
What size lines you going for?
Offline LazyLunatic
  • MK3 20VT Project
« Reply #3013 on: 26 January 2014, 21:55 »
:afro:
8mm
Offline LazyLunatic
  • MK3 20VT Project
« Reply #3014 on: 07 February 2014, 03:13 »
Bay is all welded up now, little bit more work and it'll be ready for primer. Boot is pretty much ready for primer.
Plan is to get bay and boot sprayed so I can get engine in and air fitted. At the same time the car will be prepped for primer! Pushing for Ultimate Dubs!
Also got turbo back from Turbo Clinic UK, only took a few days! All fitted, looks brand new!
Also, handheld is done, well almost. Just need to fit the screen and wire it up.
Offline Seanl
« Reply #3015 on: 07 February 2014, 06:25 »
Hope you put a little access hole in the back Alex. You may need to go back inside after your dodgy student like soldering! :grin:
Offline LazyLunatic
  • MK3 20VT Project
« Reply #3016 on: 07 February 2014, 09:25 »
:D its a little elementary haha! I'll be redesigning parts of the system at a later date; first thing being the controller! It'll be surface mounted microswitches and a demux so it'll be thin and have 75% less wiring.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #3017 on: 18 February 2014, 01:31 »
Making progress!
Air lines to front struts fitted
Polishing up the dishes on the Borbet's
Air Ride progress
Chassis notch
Engine bay in primer
Will have paint in the bay and the boot this week, and now all the wheels and engine bits, etc are in primer (no pics sorry) I can get all that lot painted too. Should have engine in and running this week too and make a start installing the air.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #3018 on: 16 May 2014, 09:57 »
Pretty much paint time
Offline VR6_Wherry
« Reply #3019 on: 16 May 2014, 10:48 »
He is alive!!
What size wheels you running? 16x9 rear and 16x7.5 front?
