Author Topic: Vag-com HELP?  (Read 2103 times)
Offline Mowzer
Vag-com HELP?
« on: 27 February 2008, 20:28 »
Hi all I have just got myself a Vag-com lead from Ebay it came with a software disk. So I have loaded all the software on to my Laptop and followed the instructions how to down load the drivers etc.
It says that every thing is working OK when I connect the lead to the laptop via the USB port so then i fire up the Vag-com programme and it says i need to test the interface and com port.
I do the test its says the com port is working but there is no interface any ideas??
Cheers guys and girls  Neil
Offline gtiscott
Re: Vag-com HELP?
« Reply #1 on: 27 February 2008, 20:40 »
are you using com 3 setting in vag com? if not set it to that and try again you also have to go into control panel on your pc,system,hardware, device manager, ports and make sure the usb one is set at com 3. this worked for me .
hope this helps
Scott
Offline Mowzer
Re: Vag-com HELP?
« Reply #2 on: 27 February 2008, 20:43 »
Ok I will give that a try  :smiley:
Cheers for the Info Scott  :wink:
Offline Mowzer
Re: Vag-com HELP?
« Reply #3 on: 27 February 2008, 21:05 »
Ive tried that still the same do I have to plug it in to the car to get the Interface to work?
Offline Mowzer
Re: Vag-com HELP?
« Reply #4 on: 27 February 2008, 21:14 »
OK looked at the COM port settings changed it to COM 3 and it worked  :smiley:
Thanks for the pointers again Scott  :wink:
Neil
Offline gtiscott
Re: Vag-com HELP?
« Reply #5 on: 27 February 2008, 21:51 »
no problem, glad to help :wink:
Offline nelds
  • Now Golfless but owning an Audi still counts
Re: Vag-com HELP?
« Reply #6 on: 27 February 2008, 21:58 »
Mowzer......do you have think link on ebay where you got lead....wot did u pay..?
Offline Mowzer
Re: Vag-com HELP?
« Reply #7 on: 27 February 2008, 22:11 »
