Author Topic: MK3 GTI 8v over fueling please help  (Read 1114 times)
Offline siigti
« on: 27 February 2008, 18:50 »
Hi there im new to this forum, i have just bought a MK3 gti 8v N reg and its over fueling plus missing on low revs (wont idle) clears off and revs above 3000rpm ecu has been checked and airflow meter aswell both given the all clear. i was told by vw it was the throttle body so i had it replaced and the car still does the same any suggestions would be greatly appreciated ,     thanks simon.
Offline boneybradley
  • Back in a Mk3...
Re: MK3 GTI 8v over fueling please help
« Reply #1 on: 27 February 2008, 21:55 »
have a good look in the mk3 maintenence section but i would try an ecu temp sensor if its more tempermental due to the engine temp or try the relays...
Offline siigti
« Reply #2 on: 28 February 2008, 00:01 »
Hi i have had the ecu temp sensor replaced so i will try the relays next thanks simon.
